cam timing experts come inside
ive tried running 22lbs and 22deg of timing and it still makes **** power
i also have a converter im going to swap out next just getting tired of shotgunning parts.
its the 3rd turbo, 2nd hotside, 3rd camshaft swap, so i think its time to start digging into the motor, 140psi compression with 317 heads
http://www.briantooleyracing.com/com...chain-set.html
had one motor stress me out with 100 across the board, grabbed another and it was 170
leak down showed it was 2%
Id do a leak down on all cylinders and that shows fine. id try another trans or make sure ebrakes or something isnt hanging up
if the cam is retarded shouldn't you be able to see it in the cam sensor to crank sensor coralation. on older engines my snapon red brick will show timing vs desired timing
I wonder if a gm tech2 whould show it. ?
I am very curious about this though. My current combo runs about the same times and mph with more cubes and TFS 220 heads. However, it will run those numbers on 4 psi less boost. Still, I have always wondered if the cam was off because both engines did not seem to backhalf as well as they should. Same cam in both.
Mike
Mike
still have to try another ECU and some other things before i get nuts on others reccomendations
