Timing cover drain issue?
Old Nov 5, 2014 | 09:08 PM
jay_rich's Avatar
Default Timing cover drain issue?
Just wondering if Ill be having drain issues with it in this location. I didn't even realize it was so close to the oil pump bolts until I bolted it on (measured about 1/4" from the bolt head to back of the cover with a shallow head bolt. I could grind it down a tad also).
My plan was to thread the fitting in with sealer then grind the backside flush.
Last setup I went into the pan but wanted to avoid drilling a brand new pan.
Jay
Old Nov 6, 2014 | 02:06 AM
95bowtie's Avatar
I put mine right below those two circles, I was going to put it right where you drilled as well but thought before hand I better check and see whats behind that.
Kinda too late since you already drilled.
I used a 45* fitting also and pointed it at 9ish o'clock just slightly angled upward.
Works perfect
Old Nov 6, 2014 | 05:43 AM
69-chvl's Avatar
Thats where I ran mine and installed as 95bowtie described. I run a -12 which is proving to be a PIA for no benefit. You can replace that oil pump bolt for a button-head allen screw for more clearance.
Old Nov 6, 2014 | 08:58 AM
jay_rich's Avatar
Well I had the stock ones in place but they stick out further. For what it is I could trim it down or a button head like said. I may have to try that tonight. I was going to plug it and shift drill a new one. I didn't even think of a button head! Thanks. Good thing I work at a tool and mold shop. Plenty of different bolts to try lol
Jay
Old Nov 6, 2014 | 09:58 AM
rotary1307cc's Avatar
Once you weld a bung on you can back cut it a ton
Old Nov 6, 2014 | 11:19 AM
67Firebird455's Avatar
Agree ^. Should be cake.
Old Nov 7, 2014 | 06:47 AM
samdogmx's Avatar
I ran mine here, welded from the front side.
