Procharger guys...
Old Nov 12, 2014 | 12:42 PM
2BAD4U's Avatar
Default Procharger guys...
Talked to Bob today with brute speed. Great guy... And answered every question I had. Now I know everyone is going to say ASTER bracket only or save and go 8 rib. I wouldn't mind going 8 rib if i could get away from using expensive ATI damper. I've got 225.00 bucks to finish this build. I'm open to larger 6 rib pulley's like MMS but can't seem to find one. Now from what I noticed theres this place http://www.sd-concepts.com/documents/LS1Tensioner.pdf That looks to offer a 8 Rib pulley that says you can use with stock crank pulley. I tried calling them 401-826-4400 but nothing happens. So not sure if they are out of business or what. So my question I guess is... Is there any places that make larger 6 Rib pulleys or 8 rib that WILL work with STOCK crank pulleys? Or do you know if SDCE is still around?
thanks
Old Nov 12, 2014 | 02:15 PM
conan's Avatar
SDCE is still around but you have to use the ATI damper as well for their 8 rib. I know its not what you want to hear but save your money and go 8 rib.
What part of Utah are you in ? I'm up in Park City.
Old Nov 12, 2014 | 04:27 PM
2BAD4U's Avatar
Really? Right on... I live in Saratoga now. Out by utah lake... You might have seen me rolling around in my other camaro. You ever come out much?
Old Nov 12, 2014 | 06:36 PM
conan's Avatar
That's cool. I get out your way every now and again, Cabelas and when the wife drags me to Ikea. Good to see another F-body in the area.
Check the classified section here on tech if you haven't already. Pulley and J brackets pop up every now and again.
Old Nov 12, 2014 | 06:44 PM
2BAD4U's Avatar
Right... Cabela's my second home. But thanks man. I've got a ad post in wanted section. But guess I'm breaking out credit card and buying ATI and 8 rib...
Old Nov 12, 2014 | 07:32 PM
ramairetransam's Avatar
fyi i have a 6 rib poor mans belt standoff ill sell you , i never used it. Its to add an extra idler and give more belt wrap .
Old Nov 12, 2014 | 09:30 PM
2BAD4U's Avatar
I'm taking its not a crank pulley?
