Using an ebay GT45 as mockup for a Borg Warner?
I had a BW S476 with 1.10 A/R T6 turbine.
I've since switched hotside to a KB Racing T4 manifold and relocated the turbo. I plan on selling the S476 T6 and swapping to either a Billet S474 (87mm T4) or a box-stock S475 (83mm T4). I can get them for the same price but the S474 is a re-man unit using an older center section.
So I was wondering if I could find a GT45 with a 4" downpipe V-band flange and use it for mock-up and possibly base tune for start-up and cruise, and then switch to the Borg Warner without too much modification. I'm guessing their size and weight is roughly the same, and that I may have to change the angle of my cold side pipes a bit if I get the longer S474.
Who has done it, and just how much did you have to change? I already know what changes will be have to made to the tune, but I don't want any other surprises to spring up when I go to do the swap.
Jay
I did a quick google images search...thread on here. POST #74
https://ls1tech.com/forums/conversio...l#post18276321
