how much hp will a ls3 block handle
Andrew
Non filled ls2 block street driven looking to go 8.6-8.40 on 24-26psi.. what will fail block or gasket..
I would think that with deck plugs or welding as you mentioned, you could easily beef that area up with good support and possibly be fairly reliable with some serious cylinder pressure.
I'm going to try a 3.82 bore 4.3 iron block with a stock crank and wiseco pistons with manley rods and see if I can make it work on E85
I don't have the bucks to step up to an aftermarket block but I'd like to hear any feedback you all might have on the LS Next Dart block
its more affordable, but to me it's hard to understand how the old school splayed main caps are stronger than a 6 bolt stock design
the block should be lighter and of course the better windage and flow between the bays
thoughts?
i feel now this block should be good to 1100whp or so, but i wont be needing to push it that hard
