Boost Leash Boost Controller
Old Dec 23, 2014 | 11:30 AM
SwampWS6's Avatar
Default Boost Leash Boost Controller
Hey guys, general question.
Do any of you run a boost leash boost controller? If so, how do you like it? Pros Cons? Compared to other EBC? Just getting a general consensus. I was thinking of purchasing one.
Thanks for the input!
Old Dec 25, 2014 | 12:32 PM
THADD's Avatar
I run it and I like it. Very easy to use
Old Dec 25, 2014 | 07:33 PM
Shoaf85's Avatar
I agree. I'm running the pulse/boost leash controller and it works great. Bumps into beams perfectly and boost is very easy to dial in with rock steady boost control. Also I am not using C02 either, my pressure source is from manifold pressure.
Old Dec 26, 2014 | 08:22 AM
SwampWS6's Avatar
Thanks for the responses guys. And this was a key point for me because I am not familiar on how the C02 system works. Most people I see that has them usually use the C02 system. I read where you can use the manifold pressure system with it.
Have you had any issues with the controller? It was a toss up between the Boost Leash and the AMS 500. I was liking the display of Boost Leash but not very fond of the C02 system. The AMS 500 was just very straight forward.
Old Dec 26, 2014 | 11:29 AM
Shoaf85's Avatar
I have not had any issues with the controller and the customer service that he gives you with the unit is awesome as well. I was considering the AMS 500 as well and have never used one. However I really don't think it gets any more simple than the Leash controller, which is exactly what I was looking for. The entire controller is easy to use and understand, the data log feature is also a great addition.
Old Dec 26, 2014 | 11:59 AM
98Camarod's Avatar
The co2 takes the place of the manifold pressure, more reliable, more consistent, and most importantly more boost while using a smaller spring in the wastegate.
