What size wastegate??
Old Dec 25, 2014 | 11:08 AM
Kmspeedie's Avatar
Default What size wastegate??
what size wastegate wouldyou reccomend for a 416 ls3 with like a 82mm turbo runnin like16lbs?.. only running one gate so im figuring i need like a tial 60 or somethin? lookin to run an EB2 with it
Old Dec 25, 2014 | 11:29 AM
dmaxvaz's Avatar
A 60mm turbosmart is what I would use. Huron speed sells them at a good price.
Old Dec 25, 2014 | 11:36 AM
Forcefed86's Avatar
If you place the gate properly you don't need much. My 42mm would regulate my boost to 9lbs with the "middle" supplied spring. Thats on a small T4 housing as well. 60mm is excessive IMO for most setups running over 10lbs. Not needed, but won't hurt anything either...
Old Dec 25, 2014 | 03:56 PM
cullen's Avatar
The lower the boost you want, the larger the wastegate you are going to need. Also, if you can't place the wastegate in an optimal position, you will need a larger wastegate as well.
Old Dec 25, 2014 | 05:37 PM
Kmspeedie's Avatar
ok well ill probly want like 8psi at the lowest with that setup for the street sometimes.. and i have the huron v1 a/c kit which people have had problems with boost creep, which they fixed on the v2 kit, but theyre so expensive for a 60 or higher, i think i either have a 38mm or 44mm im not sure what came with it.. it easily controlled 6lbs on a 7575 onna stock ls1
