Boost limit recommendations?
Old Dec 29, 2014 | 07:50 AM
mufflerguy's Avatar
Default Boost limit recommendations?
Stock 06 LM7. S475. LilJohn stg 2 cam, springs, pushrods. Trunnion upgrade. Top ring opened up to .028. LS9 head gaskets and arp head bolts. Truck intake, 80# low E injectors, Holley Dominator ecm and fuel. A2W intercooled.80% street car with a half dozen trips to the track. Hoping for low 7's on 93. Can I reach that number on a boost limit that will allow this motor to live?
Old Dec 29, 2014 | 08:48 AM
JoeNova's Avatar
Restricted User
Originally Posted by mufflerguy
Stock 06 LM7. LilJohn stg 2 cam, springs, pushrods. Trunnion upgrade. Top ring opened up to .028. LS9 head gaskets and arp head bolts. Truck intake, 80# low E injectors, Holley Dominator ecm and fuel. A2W intercooled.80% street car with a half dozen trips to the track. Hoping for low 7's on 93. Can I reach that number on a boost limit that will allow this motor to live?
Low 7s In the 1/8th is a laughable goal on any stock bottom end LS motor. The fact that you have an 07 means it has the stronger rods, which have been high 4s in the 1/8th in a 3000+ lb 275 tire car.
Watch the tune, play it safe. Don't try to lean it out or add timing for the extra power. Getting greedy on timing is what usually causes the failures in these. You can run very very fast times on 93+meth with 12-14 degrees of timing.
Let it eat.
Old Dec 29, 2014 | 10:24 AM
mufflerguy's Avatar
700 hp is what I meant, and how much boost to obtain that level?
Old Dec 29, 2014 | 10:29 AM
NoorJ's Avatar
Interested in some others opinions as well, but from what I've gathered anything under 800 should be pretty safe. My setup is very similar but with an s475 and I plan to hold it around 700, although mines an 02 LM7. And the boost required to get there is pretty dependent on the turbo
Old Dec 29, 2014 | 11:41 AM
JoeNova's Avatar
Restricted User
Depends on the cam, intake, RPM, heads, etc.
700 to the wheels will take 18 PSI on average with a large turbo, more PSI with a smaller one.
That's also a safe power on the gen 4 rods. Sure you can make a lot more, but there need to be extra precautions. The guys making 1000+ on stock bottom ends use either methanol or E85, with very safe tunes and tons of knowledge and experience. Keeping the pistons cool will keep the ring lands in place, which is why water/meth injection is recommended with gas, even race gas.
Old Dec 29, 2014 | 04:16 PM
mufflerguy's Avatar
****. Sorry guys. I just caught that I left the turbo out.........S475.........doh.
