Best knock sensor location?
Old Jan 12, 2015 | 12:05 PM
tvanlant's Avatar
Default Best knock sensor location?
I'm going to add knock sensors to my '01 LQ4 engine. I can put the Gen3 single wire knock sensors in the stock location (under the valley cover), or I can drill and tap the sides of the block for the Gen4 2-wire sensors. Which is the better location for accurately detecting knock?
I'm using Holley Dominator EFI, so I can set it up for either sensor/location.
Old Jan 16, 2015 | 08:18 AM
stevieturbo's Avatar
As long as you have it setup correctly, really wont matter much
Old Jan 16, 2015 | 08:52 AM
tvanlant's Avatar
I've heard with larger cams the knock sensors in the valley will pick up false noise, making the ls2 style better. Any truth to this?
Old Jan 16, 2015 | 09:10 AM
All knock sensors pick up noise, they're just micropohones. It's up to you via the ecu to set any thresholds to filter out background noise vs real knock.
Just go with whatever is easiest, but I would prefer a 2 wire sensor
