Turbo setup Cam question??
I have PRC 2.5 ls6 heads. I am switching to 317 heads. I would rather keep it all if its possible. I am looking for a cam that I can use with the turbo AND also sounds as close to mine as possible.
Here's my car on a cold startup and idle.
I think you're gonna run outta turbo before the heads-cam become a bottleneck for HP
sound is secondary, but your grind don't sound that aggressive. sounds close to my turbo cam. you can chop it up more in the tune if needed by.
why you getting rid of the heads? what fuel and compression?
227/227 115+5 on LS6 longblock
