Fuel lab filters
Old Jan 17, 2015 | 08:52 PM
oscs's Avatar
Default Fuel lab filters
I got caught with my *** out this afternoon. Finally took the car out for some high boost pulls and my filter ends up clogging. Left me on the side of the road for an hour so.
Does anyone know where to get a decent 10micron filter locally for a fuel lab housing? It's the 3" filter P/N 13020233. The housing P/N is 81830-1 if not I'll order one but I was hoping they could be had locally.
Old Jan 18, 2015 | 10:24 AM
oscs's Avatar
Autozone? Orielys? Come on someone give me a quick fix
I got the taste of boost in my mouth and I want more.. NOW!
Old Jan 18, 2015 | 12:00 PM
Forcefed86's Avatar
Doubt you'll find a drop in replacement.
I use these for all my EFI E85 cars. Sure you could adapt as necessary. Local tractor supply houses have them. Don't get the ones that absorb moisture. 10 micron filter with a 5 micron nominal rating. (whatever that means)
Old Jan 18, 2015 | 07:42 PM
oscs's Avatar
Doubt you'll find a drop in replacement. I use these for all my EFI E85 cars. Sure you could adapt as necessary. Local tractor supply houses have them. Don't get the ones that absorb moisture. 10 micron filter with a 5 micron nominal rating. (whatever that means)
Yeah that's what I figured. I was hoping there was a one off chance there was a local replacement. I found them for $12 on Amazon.
Old Jan 19, 2015 | 04:49 AM
Mr Monaro's Avatar
They are good filter finding room that's issue l had with 05 gto couldn't use darn thing.
cheers
