Arp head stud torque aluminum block
Old Feb 10, 2015 | 08:24 PM
josh4ku's Avatar
Default Arp head stud torque aluminum block
Hey guys, I will be installing 243 heads soon on my new aluminum 5.3 block. Arp recommended 80lb/ft . Just curious if this is what everyone is doing or higher? Ls9 head gaskets, could see boost up to 22psi.
Old Feb 10, 2015 | 09:10 PM
Kmspeedie's Avatar
80-85lbs.
JoeNova's Avatar
Restricted User
I torqued my ebay studs to 80 ft-lbs in an aluminum block.
Old Feb 11, 2015 | 06:41 AM
F110Mech's Avatar
eBay studs at 85 in an aluminum block here
Old Feb 11, 2015 | 12:13 PM
pwrtrip75's Avatar
The instructions are written/engineered to make the most of the stud within its limits, when you exceed the torque rating of the stud you then compromise its strength. I wouldn't worry about the block, the studs will break. I have broke ARP studs even when torqued to specs. More is not always better.
