Boost by gear (or speed)
Old Feb 17, 2015 | 02:40 PM
rotary1307cc's Avatar
I don't how he expected to do it with the ams unless there has been an update
Old Feb 17, 2015 | 04:28 PM
fastlt1's Avatar
If you do it off front tires, when you lift front tires you lose speed.
Old Feb 17, 2015 | 06:12 PM
TT402LS1's Avatar
The AMS 1000 needs a 0-5 volt signal from a mph sensor. From my understanding, you can set up boost levels and "ramp" the boost in each gear (or speed area you set up).
Ron
Old Feb 17, 2015 | 06:14 PM
TT402LS1's Avatar
You will, but the wheels will only be up for a short amount of time. And I don't think you should need MORE boost while the wheels are in the air.
Ron
Old Feb 17, 2015 | 06:24 PM
stevieturbo's Avatar
Ron
In that case you need to find a controller that is going to give you that 0-5v output first.
Question is...is it a linear 0-5v it wants or a simple pulsed 0/5v ? ie a hall sensor square wave signal. The two are not the same.
Old Feb 17, 2015 | 06:34 PM
TT402LS1's Avatar
I guess I'm looking for people to show me how they have set up their boost controller to boost by speed or gear. Looking for people with AMS 1000 and M6.
Ron
Old Feb 17, 2015 | 06:35 PM
Yeah that's what I was getting at. They are confused. It won't do anything with a hall effect/frequency input
And even if you had a wheel speed output in a 5v linear output it still wouldnt be a smooth arc vs speed. It would be up to 6 different stages based on voltage while being able to pick the ramp rate of each stage
Old Feb 17, 2015 | 06:39 PM
I have an ams 1000 and I like it. It is easy to use, reliable, and consistent. But let's not kid ourselves, it is past its prime.
An efi based system has waaaaay more options
Old Feb 17, 2015 | 06:54 PM
Really AMS should be advising what is needed then.
And fully agree, a good ecu controlling everything usually gives many more options.
That said, if the EBC is also good, sometimes the simplicity they offer....if they are simple lol can also be a good thing.
What irritates me is the ones who claim boost by speed, boost by gear...etc etc, yet the reality is **** all like that, or they're very complicated to make those features work etc
Old Feb 18, 2015 | 02:54 AM
skinnies's Avatar
Just to be clear, my comment wasn't directed at using the hall sensor for the ams1000, I mention in my post using the hyperkontrol and holley efi. I highly recommend if you want mph based to go one of these routes. The hyperkontrol you can set boost every 1 mph to 1/2lb of boost difference.
The hyperkontrol also has a built in accelerator for the track so you can run it that way if it carries the tires bad and not have to worry about changing tuneups to boost vs time.
Old Feb 18, 2015 | 07:37 AM
Don't worry I know you know what is what lol
Old Feb 19, 2015 | 06:35 AM
  #32
skinnies's Avatar
I know, I was just clarifying for others in case they didn't.
Again the hyperkontrol is a great unit, only reason I don't run it anymore is I use the holley efi now.
Old Feb 19, 2015 | 08:00 AM
  #33
boss79z's Avatar
Skinnies, I am getting ready to purchase a boost controller for my setup. It will either be the AMS 2000 or the Hyperkontrol. How user friendly is the Hyperkontrol unit?
Old Feb 20, 2015 | 12:08 PM
  #34
TrendSetter's Avatar
i built a bracket with four snap switches and a resistor divider network to tell my ams1000 what gear I am in. it gets +12v from a WOT switch that is activated around 65%, so the ams only tries to control boost in gear under heavy throttle. it works very well all things considered.
Old Feb 20, 2015 | 03:24 PM
  #35
Lol wow. Made it work that is for sure!
Old Feb 20, 2015 | 09:44 PM
  #36
oscs's Avatar
Crafty little bastard aren't you.
Old Feb 21, 2015 | 07:27 AM
  #37
my truck is full of little things like that.
I challenge myself to solve problems that nearly dont exist
Ive been running that gear setup for about 6 months now and its been awesome, in case anyone else decides to try it out. with all the stock console and boot in place you cant even tell its there.
Old Feb 23, 2015 | 11:03 AM
  #38
turbo_bu's Avatar
skinnies,
Do you use just the Holley setup, or are you using like a Davis box with the Holley?
