Phase 2: Hairdrying
Old May 7, 2015 | 08:42 PM
  #41
Meth Sled's Avatar
What are you running off of the waterpump?
Old May 8, 2015 | 09:43 PM
  #42
tiresmokinV8's Avatar
Running 90* fittings
Got the 90* NPT fittings today for the waterpump
Also got the passenger side intercooler pipe all welded and BOV flange installed.
Finished fiberglassing in the gauge pod
Doesnt look like I got a pic of the pod with coat of primer.
Think I got it figured out what I have to do with the maf and other sensors so the drivers side piping is basically getting redone. So Ill be back at it.
Old May 10, 2015 | 09:35 AM
  #43
Worked on fitting the massive 3.5" downpipe. Took a good chunk of the day but it fits well and I can take it out in one piece. I was afraid I might have to make it a 2 piece downpipe Some places look close but the closest place still has 1/2" of clearance plus Im going to wrap it.
Still deciding what to do with the wastegate piping. Either just leave it like this or make up a exhaust pipe for it and route it to the bumper area. Im afraid if I leave it as is theres going to get a lot of soot on the from rim.
Kind of at a stand still for the rest of the intercooler piping until I get a cone that goes from 3" to 3.5" alum so the maf, seperate IAT and meth inj will be in a 3.5 alum pipe then a 3.5" to 4" 90* elbow into the TB.
Old May 13, 2015 | 05:38 AM
  #44
New drivers side intercooler piping in a nutshell.
3" into a 3.5" which will contain the maf, 2 meth nozzles and the seperate IAT sensor in that order towards the TB.
Old May 13, 2015 | 01:08 PM
  #45
IronBlocked's Avatar
You have a lot of skill man, keep it up
Old May 17, 2015 | 07:38 PM
  #46
Put the textured coating on the gauge pod then finish painted it before installing.
Wrapped the downpipe.
Borrowed a threadsert tool from work. These things rock
Also got a lot of the engine bay buttoned up.
File Type: jpg
Old May 18, 2015 | 09:21 PM
  #47
Got the rest of the exhaust fabbed up still need to add another hanger at the end. Should make a bit of noise yet.
Old May 20, 2015 | 07:04 AM
  #48
Intake piping is all done! Well enough to run. We decided not to weld the cone and/larger pipe to the elbow since the piping might need to be rotated to get a steady MAF reading.
Sexy welds
Finished the exhaust too!
Old May 21, 2015 | 07:42 AM
  #49
Buttoned the rest up last night. Exhaust is on and done, everything is ziptied securely so it doesnt get burnt. Autozone didnt have enough 1/4 line for the wastegate and BOV so I couldnt drive it but I did let it idle and fill the cooling system. Sounds pretty mean. Started working on securing the hood latch since I cant run a bar down like factory anymore. Shouldnt take too much to finish that then I can start tossing things on and see what I have to do to get the hood safety latch to clear the intercooler.
Old May 22, 2015 | 10:26 PM
  #50
Needs some tuning but I drove it today around the block.
Old May 24, 2015 | 06:51 AM
  #51
Some photos from the last couple of days
Grabbed a summit aluminum overflow tank since the factory wont fit
Going to have it powdercoated whenever I get the intercooler pipes powdercoated.
Also got a Thermal Zero turbo blanket off ebay Fits well and does the job
Had to modify the hood latch by bending it forward to clear the intercooler. Then cut out a good section infront of the factory cut out for the latch.
And finally I tossed the grill on which needed trimmed and the billet insert removed. Stealthy huh hahahah
Brother and I drove and tuned for a few hours last night and got it pretty solid at 10 psi. Still havent run through the gears at wot but just rolling onto the throttle for a bit. Only got it to 90% TPS.
But got it ready for the biggest carshow of the year today so there will be some great pics from that.
Old Jun 3, 2015 | 07:16 AM
  #52
Some update. Trucks been running decently. Made a couple WOT 40mph pulls and it just hauls.
Won a trophy at the show over memorial weekend.
Also went back to some work duty hauling stuff.
Picked up a nice Cub Cadet 3184 with 44" deck, Triple Bagger and plow.
Then Picked up a bunch of lumber to fence in my 18x20 garden.
Pulls really well, and cruises really well. However during my inspection of things after putting some miles on it I found this crap.
I just replaced the coils last October and have maybe 500 miles on them.
Why does my drivers side suspension hate me so much.
Old Jun 3, 2015 | 05:32 PM
  #53
So happy to hear about the truck, looks terrific with that fat tire on the back
Old Jun 6, 2015 | 10:11 PM
  #54
Thanks man!
Tomorrow I hope it rains so I can stop doing outdoor projects and get back in the garage haha. Have to change out the drivers coil spring, Wire up the lighting for the 3 new gauges and figure out way my fuel pressure just stays at maxxed out.
I did take it over to my parents today so I could help my dad on a home remodel project and got on it on the highway. Looking at the boost gauge for the first time going wot through a gear and not only the wideband I found out my singe 46mm wg isnt up to the task. I have 7.5# springs in there which at 90% throttle brought me to 10 psi just rolling into it but today going all out it hit 15 psi at 6000 something rpm. so Ill be adding a second 46mm wg onto the crossmember somewhere.
Old Jun 8, 2015 | 09:01 PM
  #55
No sign of binding
all fixed for now.
Old Jun 18, 2015 | 02:02 PM
  #56
bonecrrusher's Avatar
Lost your other thread - come back to find you boosted!
Thats awesome! Keep up the good work.
Have you figured out your suspension issues yet?
Old Jun 20, 2015 | 02:01 AM
  #57
BSmiff's Avatar
Damn springs hahaha. Im surprised you havent put the ZR1s back on the back.
Old Jun 21, 2015 | 08:51 PM
  #58
The zr1s are back on, doesnt hook up under 45 going WOT though hahaha. But then again the single wastegate isnt in a good spot because its not keeping up and creeps to 15psi with the 7# spring in it so Im adding a 2nd WG and in a better spot.
Picked up a compact Turbonetics Comp 40 wastegate.
Found a good spot off bank 1
and got it tacked up ready to be tigged and purged.
Also bought a replacement windshield washer tank so I can finally hook up the meth and a hallman manual boost controller.
Old Jun 22, 2015 | 08:49 PM
  #59
2nd wastegate piping all tigged.
And wrapped
Also my Hallman manual boost controller came in!
Old Jun 24, 2015 | 09:20 AM
  #60
Crossover is back in, Have to make a short exit pipe to get the exhaust away from stuff but theres plenty of clearance everywhere.
Also started putting the Meth Inj kit in.
