o2 sensor ?
Old Mar 6, 2015 | 07:49 PM
players 91's Avatar
Default o2 sensor ?
Was looking for some info on o2 placement and couldn't find what I was looking for. How many sensors should I run and where do I place them. Saw some pics where you only see one in the header. The I believe I should put 2 in the down pipes. Would it be the wide band in the header?
Old Mar 6, 2015 | 08:18 PM
JoeNova's Avatar
Restricted User
Wideband in the downpipe.
Whether or not you run OEM O2 sensors has a lot to do with what tuning hardware you're using. If you're using the stock computer with something like HP Tuners, you'll need to run O2 sensors. Something like Microsquirt, you can remove them.
