Ls3 to lsa conversion
Old Mar 10, 2015 | 10:41 AM
laurentj23's Avatar
Default Ls3 to lsa conversion
Hey all. I'm building an ls3 from l92 block and ported ls3 heads. I was contemplanting whether to increase the ci to 416 or go and do the lsa conversion. So here are a few questions.
1. I've read that stock ls3 rotating assembly is pretty stout. The only upgrade im going to make is using arp rod bolts or katech. Should I upgrade the main stud?Thinking abt high 500 hp max. What is the different between katech and arp besides price? I will also be going with morel tie bar lifters.
2. I'm gonna get a used ctsv or zl1 supercharger. What shld I look for when buying a used unit. Besides the reluctor need to be change.
3. Can I use ls3 valley plate or lsa? Or are they the same thing.
4. I'm gonna use ls9 cam and headgaskets. Any reasons why I shld go against it?
5. What is the different between ctsv ,zl1 and zr1 superchager. Is it worth the upgrade? How about the magnuson,edlebrock units?
Old Mar 10, 2015 | 12:29 PM
gnx7's Avatar
Skip the supercharger, do a 416 with ported heads, medium cam and make 500rwhp +
The LSA supercharger can be had for $750 used and then needs injectors/rail and the intercooler lid for another $700 approx. But the pulleys need to line up also. It can make 600rwhp+ with headers/pulley upgrade/tune/e85.
For simplicity and your 500hp goal just stay n/a stroker.
