Pushrod length
Old Mar 25, 2015 | 10:34 AM
lickinpink's Avatar
Default Pushrod length
hello all, been lurking around the forum for quite some time now and finally came across a block that will work for me. I've got an 07 aluminum 5.3 with 74k on it. I will be getting rid of the active fuel management and already have a few parts piled up to start throwing it together. Haven't decided on a turbo yet but looking for around 650-700rwhp with room to grow. The next thing i am running into is figuring out if i need to replace the pushrods if i use a z06 (ls6) cam in it with 243 heads and ls9 gaskets. Ive read that you may need a little longer pushrod then others say you should be fine just less preload. Still searching for a used cam if anyone has one available too. Thanks in advance for all the help!
Old Mar 25, 2015 | 11:01 AM
cptinjak's Avatar
Any time you change something you need to measure for correct pushrod length. You cannot know for sure without checking.
Jack
Old Mar 25, 2015 | 11:30 AM
lickinpink's Avatar
Thanks Jack i appreciate it! any suggestions on places that have reasonably priced hardened pushrods?
Old Mar 26, 2015 | 04:08 PM
cptinjak's Avatar
I would recommend finding a local engine pro distributor and buying the EP brand 5/16" pushrods. They usually stock any length you'll need in .050" increments.
Jack
