Which O2 sensor should I use
Old Mar 27, 2015 | 08:35 PM
t-town's Avatar
Default Which O2 sensor should I use
Hi everyone. I have been lurking here for awhile now soaking up as much info as possible to help me with my project. I am doing a fox mustang with a 6.0 and 4l80. I am going to use the on 3 fox/ls turbo kit with a single turbo. I am planning to use the stock PCM and wire harness after modifications
My question for you is what O2 sensor do you use with the stock PCM? Do you use a wide or narrow band sensor? I believe I need to put it on the down pipe after the turbo but am not sure. Any help will be appreciated. Tony
Old Mar 27, 2015 | 08:40 PM
JoeNova's Avatar
Restricted User
You need a wideband sensor in your downpipe.
Old Mar 27, 2015 | 11:14 PM
SPRAYED 01's Avatar
Use a wideband in the down pipe for tuning. If your going to run closed loop for daily driving then run 2 narrow bands in each bank before the turbo. You could get those at any auto parts store
Old Apr 16, 2015 | 06:13 PM
t-town's Avatar
Thanks for the input guys!
Old Sep 10, 2015 | 11:49 AM
Jwooky's Avatar
Why do you recommend before the turbo?
