need advice from cam guru's
Old Apr 11, 2015 | 06:20 PM
toughy v8's Avatar
Default need advice from cam guru's
Ive came across a used cam for sale from vengeance racing.its a 219/215 .604/.601 115+3. Im curious to know if this work on my 4.8 gt45 combo. Thanks
Old Apr 15, 2015 | 12:36 PM
toughy v8's Avatar
Anyone?
Old Apr 15, 2015 | 01:03 PM
stevieturbo's Avatar
It odd no answers.
I'd have no hesitation in using it...but is it really that cheap ?
Old Apr 15, 2015 | 02:41 PM
toughy v8's Avatar
Im also surprised too stevie i might try the turbo forums instead.
Old Apr 15, 2015 | 07:19 PM
TurboS10's Avatar
LSA is a little wide for that small a cam but it will work.
I got Duttweiller to answer a question one time on LSA for a 215/215 HR for a gen 1.
He said 112.
Jim at Speed Inc ran a 218/218 113 LSA in his gen II and made 875 or so rwhp. 61mm TT.
Old Apr 17, 2015 | 05:42 AM
toughy v8's Avatar
Could you explain to me the plus 3 part? is it ground in advance? Or does 115+3 really just mean 118.
Old Apr 17, 2015 | 06:48 AM
Never really understood that myself.
You'd think if the entire cam was ground with x deg advance...they would just list the cam as timing at x deg advance rather than stating +3 somewhere
The 115 refers to the LSA, not the actual valve timing
Old Apr 17, 2015 | 02:51 PM
stock48's Avatar
9 Second Truck Club
The + after the lsa normally means the advance ground into cam. A 115 +3 is a 115 deg lsa ground to a 112 ICL (intake center line). In short + 3 deg of advance ground in.
Old Apr 17, 2015 | 04:00 PM
toughy v8's Avatar
So stock48 whats your opinion on the cam ive mentioned?
Old Apr 17, 2015 | 11:48 PM
stock48's Avatar
9 Second Truck Club
Depends on what lobes they are.
