TT 408 numbers
Old Apr 15, 2015 | 10:01 AM
  #41
oscs's Avatar
Originally Posted by Orr89rocz
Would be interesting test. But i know some small block chevy aluminum heads have similar deck thicknesses as lsx stuff but dont seem to lift due to 5 bolts per cyl. Think theres something there with bolts per cyl for sealing.
No doubt the increased studs help with sealing. However in theory superior material should be able to hold its shape with less clamping force. I cant be the only person who has though about this. There must be someone out there who has boosted the **** out of some iron heads with some results.
Old Apr 15, 2015 | 10:49 AM
  #42
asubennett's Avatar
Heat soak would be terrible on a boosted application with iron heads. Whatever you gained in sealing you would throw away and some with heat retention in the heads.
Old Apr 15, 2015 | 11:03 AM
  #43
oscs's Avatar
I would venture to say if you could (not saying you can) push iron heads say 10lbs further than aluminum you would absolutely pick up more power. Not to mention there are plenty of ways to keep the combustion chamber cool.
Old Apr 15, 2015 | 11:21 AM
  #44
Orr89rocz's Avatar
Yup plus iron on iron, have same coeff of expansion so that also help keeep things sealed.
I would run abit lower compression with iron heads to lower chamber pressure and thus lower heat.
But arent iron heads rare for these motors?
Old Apr 15, 2015 | 11:24 AM
  #45
gnx7's Avatar
Unless you mini tub your car.... can you really use 1000rwhp?
Old Apr 15, 2015 | 11:37 AM
  #46
oscs's Avatar
Absolutely.
Old Apr 15, 2015 | 11:38 AM
  #47
oscs's Avatar
This is what im thinking. Also it just so happens i have a set.
Old Apr 15, 2015 | 03:44 PM
  #48
tblentrprz's Avatar
Heat soak and slow transfer on iron is a recipe for detonation. Curious how much timing will be allowed with E85 and meth injection (if needed).
What is the thickest deck 4 bolt aluminum head available, RHS .800"?
Old Apr 15, 2015 | 04:35 PM
  #49
oscs's Avatar
Curious about iron head timing or aluminum?
Old Apr 15, 2015 | 04:41 PM
  #50
asubennett's Avatar
If iron heads were the answer, guys running 6's with ls motors would be running them. They are not.
Your best case scenario to make a 4 bolt head live is the following....
1. fill the block to the water holes
2. Machine for 1/2 head studs or use the arp625s. They are expensive though.
3. Look up Andreas on this forum and order his fire ring head gasket from Sweden. 250 per side. He has used them to 2000hp on a 4 bolt head.
4. Buy billet main caps and use an amazing crank. Dragonslayer or better to ensure integrity and limit flex inside of block.
5. Ditch motor mounts. Motor playe your car. Mounts pull down on sides of block and enhance head lifting at high load.
6. Don't tune it too rich. Keep it happy with E85 but don't flood the pig
7. Use cold, cold plugs. Colder than you think.
8. Keep timing in check.
9. Don't spin it too high. Match turbo efficient with rpm band of 5500 to 7500.
That's your best hope with this project.
Old Apr 15, 2015 | 04:49 PM
  #51
oscs's Avatar
Not disagreeing with your suggestions but out of those 6 second cars how many do you think are still running a 4 bolt head?
  #52
stevieturbo's Avatar
The above covers a lot...the bottom line is do not get greedy with timing no matter what the setup.
Old Apr 15, 2015 | 04:54 PM
  #53
asubennett's Avatar
Let me rephrase, of all the 4 bolt set ups running mid 7s to low 8s, how many are using iron heads? 😊
Old Apr 15, 2015 | 04:55 PM
  #54
oscs's Avatar
Let me rephrase, of all the 4 bolt set ups running mid 7s to low 8s, how many are using iron heads? ��
Now that makes a lot more sense. Also i wonder how many of those guys have tried a set. I don't really want to get into an argument about Iron heads vs. Aluminum seeing as no one has any real data to prove one opinion over the other.
The fire ring idea seems like a good one also with a half filled block i imagine that would decrease street driving capabilities quite drastically?
Old Apr 15, 2015 | 05:06 PM
  #55
asubennett's Avatar
Depends on if you half fill with aluminum heads or iron for heat dissipatation. LOL
Look at non lsx x275 turbo cars that are running bottom 4s to the 8th at 170 plus. All aluminum heads regardless of motor platform.
If your hell bent on iron heads do it and report back. My hunch is you will knock or break something because of the heat retention with a normal, traditional boosted ls tuneup.
Old Apr 15, 2015 | 05:15 PM
  #56
oscs's Avatar
Hell i was throwing the idea around. By no means am i hell bent. The only thing Im hell bent on is making 1300whp and still be able to drive to the grocery to pick up dog food.
Old Apr 15, 2015 | 05:30 PM
  #57
asubennett's Avatar
I share your desire. I'm going to push to 1200who on next set up And I've done all on list except for half fill block and fire ring head gaskets.
I stopped at 850who and 16lbs on dyno with 370. I ran a tick over 20lbs at track and went 164. Guessing it was in 100who range. Hoping to get it into 170s.
Old Apr 15, 2015 | 05:37 PM
  #58
oscs's Avatar
Yeah your **** is working for sure. I honestly have no idea what I'm making at 25lb and E85. First order of business when this trans is done is to head to the dyno and see what it does. Then its off to royal purple raceway and see if i cant break something else.
Old Apr 15, 2015 | 05:42 PM
  #59
66Chevellelq4's Avatar
If you fill the block doesn't that mean your coolant passages are gone? I dont think a grocery getter can pick up groceries without coolant lol
Old Apr 15, 2015 | 05:44 PM
  #60
oscs's Avatar
yes and no. I think there is a certain level you can get away with. Im not sure though, Never looked into filling an LS motor
