Backpressure issue help.... ugh...
Old Apr 17, 2015 | 10:42 AM
rotary1307cc's Avatar
Bigger turbine the better...
Old Apr 17, 2015 | 11:33 AM
Phish806's Avatar
Yeah, Right now the plan is the T4 S476 with a 92m turbine. I have a friends turbo sitting in my garage thats basically the same physical size. From looking at it, i think i can get it to work with quite a bit of modification. I am also planning on going with the 1.0 housing instead of the 1.25 housing.
Old Apr 17, 2015 | 11:37 AM
You can have a 96mm in the same package just saying... Just costs a little more
Old Apr 17, 2015 | 11:44 AM
Phish806's Avatar
What would the pros/cons be of the 96mm turbine over the 92mm?
Old Apr 17, 2015 | 01:01 PM
TRIXLSXSUPRA's Avatar
Sorry if this is slightly off topic as i don't mean to de-rail this thread i'm just hoping to alleviate potential issue with my set-up.
The OP has this as a "single" turbo set-up correct?
I'm planning on running the CT43 78/79 but two of them......will i be ok w/ the T4 .96 a/r for each bank of cylinders?
Thanks for the info posted already!
Old Apr 17, 2015 | 01:10 PM
asubennett's Avatar
Yes - with two of them - you are good to go/ Especially with the .96A/R
Old Apr 17, 2015 | 02:14 PM
Phish806's Avatar
Correct, you will be ok with two of them. Now convince someone to buy my 8079.
Old Apr 17, 2015 | 02:16 PM
None on your setup
Old Apr 17, 2015 | 04:04 PM
Good to hear carry on i'll still be reading/learning as you can never learn too much!
Old Apr 17, 2015 | 04:27 PM
SPRAYED 01's Avatar
I wish I could barrow someones bw s476 with the 96mm turbine. Id love to see what the difference is compared to my custom comp turbo.
