TT Ranger mega truck
Old Apr 24, 2015 | 08:43 PM
hondarider2289's Avatar
Default TT Ranger mega truck
Getting close to being all the way done with my build, so i figured I'd start a build thread here, not the typical build you see on here.
Specs:
1991 Ford Ranger extended cab body
4x2 tube frame
2" subframe
Triangulated 4link front and rear
2.5 ton Rockwell axles
49" tractor tires
built th400, mated to a military t-case
Motor:
2005 l33 5.3
Tick performance stage 3 5.3 cam package
On3 performance up and forward headers
Vs racing 90 T-4 to 3" vband 90s
Twin 70mm on3 performance turbos .68ar
80lbs injectors
a1000 pump
-8an feed -6an return
Chassis is done, motor is almost done, waiting on a few parts, then heading to the dyno, pictures coming.
Old Apr 24, 2015 | 10:25 PM
danbap's Avatar
pictures?
Old Apr 25, 2015 | 01:55 AM
Picked up a set of Rockwell 2.5 tons
And some steel to build the frame from
Old Apr 25, 2015 | 01:57 AM
Start of the frame
Old Apr 25, 2015 | 02:06 AM
Got some coilovers
At this point my build starts to change directions several times, for various reasons...
Picked up a toyota xtra cab and flatbed and mocked it up on the frame
Old Apr 25, 2015 | 02:09 AM
Bent a subframe up
Old Apr 25, 2015 | 02:14 AM
Added a couple verticals to the subframe
Picked up some wheels and tires
And mounted them with the help some ratchet straps
Boostedhatch's Avatar
With that gearing and that turbo it should be a beast in the muds pits.
 Michael S. Palmer
Old Apr 25, 2015 | 02:20 AM
At this point I decided that I wanted to set this up as a rear motor, and that a flatbed wouldn't work for me, so i started hunting a clean toyota bed. After coming up empty, I picked up a stepside ranger bed to put on it.
The ranger bed is around 7 1/2" to wide, but the body lines match up almost perfect.
Old Apr 25, 2015 | 02:24 AM
I didn't take any pictures of the 4link while it was going in, but it's dual triangulated front, and rear.
Everything tacked together and rolled outside for the first time
Old Apr 25, 2015 | 02:29 AM
Originally picked up an 8.1 for it that i was going to boost
Old Apr 25, 2015 | 02:36 AM
Got an old transfer case from my buddy, supposed to be from an old military truck, but I don't know that much about it. If anyone recognizes what it's out of or anything on it, I'd like to know. It's plenty beefy, and had the drop I was looking for so I decided to run it.
Old Apr 25, 2015 | 03:09 AM
Final picture of the build before it all changed up
I realized that 8.1's weren't the most boost friendly motors at this point, and they are expensive compared to 4.8, 5.3, or 6.0s. There's also almost zero aftermarket support for them, so i sold it. Picked up an L33 5.3 to replace it, and swapped them out.
At the same time I was battling rust issues with my Toyota body, so I switched it out for an earlier ranger body.
Had to put it on the little tires to swap bodies
Back on the tractors
Old Apr 25, 2015 | 03:13 AM
Rolled it back inside, with the new body, and 180,000 mile 5.3 in
Old Apr 25, 2015 | 03:29 AM
Fitted the bed to the frame, and cut out around the motor
Old Apr 25, 2015 | 03:33 AM
Took it all apart to weld and paint the frame, and cut the cab for the transmission
And started putting it all back together
Old Apr 25, 2015 | 03:40 AM
Rolled it all outside to clean up, and my on3 performance headers showed up, so I threw them on.
Back inside to start the cage, and wiring
Old Apr 25, 2015 | 03:56 AM
Got my turbos
Put the cage, and corbeau seats in, didn't get very many pictures of that, and wired everything up to get the motor fired. Started right up first try in 20 degree weather, and I could move this thing around under it's own power for the first time.
Started my turbo setup, ordered vs racing 90* t4 to vband elbows
Have the intercooler mounted, radiator mounted, oil drains done, and that's about where it's sitting now. Waiting on my Tick performance cam to come in, my throttle body adapter, and my oil feeds, and then I'm headed to the dyno. Hopefully have everything done by the end of next week.
Old Apr 25, 2015 | 06:17 AM
AnotherWs6's Avatar
This guy is awesome.
Old Apr 25, 2015 | 07:37 AM
ls1_chevelle's Avatar
I want this
