$2000 Turbo Kit
Old May 1, 2015 | 12:13 PM
Cody5's Avatar
Default $2000 Turbo Kit
Heys guys a have a 4.8 sittin at the house and was wondering. Is it possible to piece together a good turbo kit that can put down about 700 hp for under $2000? I can do the work just curious if tat can be done under that budget.
Old May 1, 2015 | 12:17 PM
JoeNova's Avatar
Restricted User
If you can weld, yes.
That includes hotside, turbo, wastegate, intercooler, coldside, oil feed and drain, and odds and ends.
Old May 1, 2015 | 12:57 PM
IronBlocked's Avatar
Have in mind you're gonna have to feed those horses
Old May 1, 2015 | 01:07 PM
willizm's Avatar
Definitely use some truck manifolds. Should be able to pick those up cheap. Then you are just looking at the crossover and downpipe for the rest of the hotside. As IronBlocked had mentioned you'll need to put some money toward a fuel system as well. Read the sloppy mechanics page. He always posts best bang for the buck and budget type information.
Old May 2, 2015 | 01:30 PM
1CAMWNDR's Avatar
As others have said....outside of the fuel system and tune yes you can do hard parts yourself for around $2000. Will it be pretty? Doubtful. But if you can weld and are careful, and thorough, you can achieve some good stuff.
