Twin s366 wastegates too small or?
Im going to vent the gates to atmosphere and see what happens, if all else fails the car runs pretty good as is
Thanks for the suggestions/info.
Rotating the gate around, that would be an easy test.
But IMO it will not fix the problem. Work with the gates so they are installed as normal, but the poppet valve inside is maintained in a fully open position. That way you're testing the gates max flow as it is installed in the car.
If you cannot get boost down, you need a larger pair of gates.
The Tial 44's may be a straight swap, or maybe Precisions 46mm
Flipped them to open to atmosphere... No change
Removed springs so they were wide open to atmosphere... No boost
Teed in gauge where they tie into cold side, same pressure as boost gauge that is on intake manifold so they are getting refrence
To verify i pulled hoses off of the gates, got 25 psi REAL quick where i would normally have 10. So the gates are doing something.
I moved the refrence to the intake for the heck of it, no change
i may do what i can to the area where the gates hit the collector and see what happens, if no change then id guess bigger gates it is.... Or just enjoy 15+ psi all the time! Ha
Really...are you suuuuurreeee the springs are/were what you think they were ?
A single 1/4 line to both gates should not pose a problem.
If there is a lot of leakage past the shaft of the valve, I guess you could either run dedicated lines each, or a larger 5/16" line. There will always be some leakage past the shaft though.
And back to springs, are you sure they arent coil binding, catching on something inside etc ? Nothing limiting the travel of the valve ?
They were vented to atmosphere durring that test
Maybe if they are open from the start with no boost it will not build boost vs. opening with boost and not being able to keep up? Ill mess with it some more this evening
I may try to improve on the location a bit, which im sure will help, but my non expert opinion says bigger gates would probably be needed
Ill keep ya updated. Thanks!
Was this done with gates vented to atmosphere or to downpipe?
Really you may be able to much about, cut/re-weld and gain some benefit and it might get you where you need. The operative word being might.
With larger gates, there is little doubt it will achieve what you need.
