Camshaft Advice for Turbo Setup
Old Jun 3, 2015 | 10:59 PM
LSFOX's Avatar
Default Camshaft Advice for Turbo Setup
Currently have roughly a 10.3 to 1 motor
JY LQ9 with L92 heads and Ls9 Headgaskets, also Holley HP EFI tuned
Looking to add the On3 Single Turbo Kit with the 78/76 turbo and 4" intercooler.
Need help with a custom cam that can bleed off some of the Dynamic Compression so i can still run 93 Pump gas
just planning on 10lbs for now till I get the Alky Control Kit and add straight meth to the mix.
Is this doable or am I really stretching here...
Thanks in Advance
Old Jun 4, 2015 | 06:13 AM
yenkomike's Avatar
i whould cam it like for power and be carefull with the tune and timing. any cam you go with to bleed of compression will bleed off power and add spool time. get a good turbo cam and just be conservative until you get your meth.
with a good intercooler you should still be able to un 10# boost if you keep it cool and don't get greedy with the timing.
Old Jun 4, 2015 | 06:42 AM
LT1PWRD's Avatar
Martin @ Tick... bam done!
Old Jun 4, 2015 | 08:20 AM
Orr89rocz's Avatar
Any mild cam would work. 10 psi on that wont be much. Ppl run that on stock ls3's
Old Jun 4, 2015 | 09:06 AM
kk90's Avatar
tick performance stage 1 turbo cam problem solved.
