ok, here we go.
I have so many things in the fire right now I cant see straight. Trying to sell my insurance agency. Trying to get more work for my masonry company. And just started a home building and remodeling company that I am trying to get off the ground. I am the poorest 3 business owner in history. LOL. So money is tight and that's why I am going for a budget build. I want to have a little fun sooner than later. Otherwise this thing would have a super bad *** engine and big twins, full cage and maybe chassis. That's how I really like to build stuff. All I can get or nothing.
I found this one that I think will work and the price is good. What do you guys think about it working for me? HP range allows me to keep it down for the street and turn it up at the track.
At Turbodaves
On-Line Special
S400SX4-75mm T-6 1.32 A/R Exhaust 500-1050HP
$639.99 Free Shipping (To Lower 48 States Only)
Turbo Specs:
Compressor Inlet - 5 Inch
Compressor Outlet 4.21 Inch V-Band,
Compressor Wheel Inducer/Exducer - 75 x 100mm with ETT,
Turbine Wheel Inducer/Exducer - 96 x 87mm
Turbine Inlet - T-6 Divided,
Turbine Outlet - 5 Inch Marmon V-Band,
Turbine A/R - 1.32
You lose alot of the heat between the valve exit and the turbo the farther back you go. For that reason I think the 1.32 housing would be on the laggy side. Esp with a 2.5" hotside. Better off with the 1.10 T6 housing.
If you keep the hotside as short as possible and put the turbo behind the cab it's not as bad. Still you'll want to neck down to 2.25" minimum from the collector to the turbo(s).
IMO if you go remote you should do twins. It will help with spool time and is just a more efficient setup than a single. You'll have better spool with less back pressure.
I've been looking at a set of T3 hy35's for a buddys remote build. They also have built in Wastegates for $201 each. They have nice wheel sizes and the smaller housings would help in a remote setup.
If moneys not a big deal S366 turbos are $550 each and more than capable of huge numbers.
http://www.ebay.com/itm/221270359589?_trksid=p2060353.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
All that said if you still go with the 1.32 S475 shoot me a PM. I have a link to get it for $624 shipped.
I did have a feeling that the 1.32 A/R would be laggy at such a distance. If I can fit this turbo under the hood and get back to the standard setup, would it work well? I am just trying to avoid installing it under the hood because I don't have a ton of room to run everything and it will be really cluttered.
On the CX turbo. I am still trying to convince myself that Chinese is ok. LOL But its an option.
http://www.vsracing.net/catalog/prod...oducts_id=1354
I don't mind the Chinese deal I guess. As you mentioned there are a lot of people running them and most run fine. So I just need to pick one. That's the hardest part of this venture, the choosing of a turbo that will work.
I am leaning towards the CX turbo mentioned above due to it being a ball bearing. I would go with the VS as well if its a better setup for me. They just don't show specs on the website for it.
Oil pump system/pump in case I place it in the bed.
BOV, I am thinking 50mm. VS has the Tail for 220.00
Wastegate, not sure what size to get. Thinking 48 maybe.
IC, A/A I am going to try an get a 4" thick to fit. I will get the biggest I can fit. 3" in and out. I would like to go A/W but not sure how good this is for street use. How long might the ice last?
Deka 80lb injectors
I will need a new inline fuel pump. I currently have an Aeromotive A750 which isn't enough. I think this was mentioned before in this thread. I'll read back on it.
Pressure regulator.
Ok, Now to the stuff I need vs what will or can come later. And I do not know everything that's needed or that will help. So what do I need for now to get it going. Verus what are the nice extras to get later.
Boost gauge.
Maybe A/F gauge?
Hell that's about all I know. I know boost controllers but can this be set manually with springs?
Anything else?
For piping.
I plan to run all 3" on cold side from Turbo to TB. Will this be ok in both setup applications? Under hood and bed mount?
Hot side. If its bed mount. I currently have dual 2.5" I am guessing I would merge the two pipes into a single 2.5" and then reduce that single down to the 2.25" before the turbo. Any suggestions?
If under the hood I would come off the header or manifold with 2.25" and do the standard piping tot he flange.
For the bed mount. I know the mention of losing the temp in the exhaust pipe. Isnt that a good thing so it keeps the turbo temps down a little? Also the distance. This is a standard cab short bed truck. I am really not adding that much distance from under the hood setup. The opposite side manifold from the turbo is going to have quite a few feet of pipe to reach the turbo. It may only add a couple more feet to reach the bed. I will have to take some measurements.
Thanks for all the help guys. I have read and read until my eyes are crossed. But I still don't want to screw this up. I think I have the basics but....
All the ******* claiming 1000whp usually have closer to 600whp according to weight and trap speed. Ignore the dyno BS hype, look at weight and trap speed. 1000whp is more than the current SBE 6.0 record holder is making. I really don't think that number is a reality for most SBE guys.
That said...
VS BOV and WG sizes U mentioned are fine.
VERY little difference between a ball bearing VS standard journal bearing turbo on spool speed. Not worth the extra money. Since your going for the moon power wise, go with the biggest single you can afford. To have any chance of hitting your goals a really nice single ($1800+) or twins will be necessary IMO.
Your current pump doesn't flow well at boosted fuel injection pressures. (neither does the A1000) You want a pump that flows at decent pressures. To make 1000hp you'll need alot of flow at high pressure. If you don't want multiple pumps look at the 4303 magnafuel.
You'll pay 300-400 for a good scavenge pump. It's not something you really want to go cheap on. Ebay sells some knock off stuff, but I don't know anyone that's run it with success. Turbowerx, and RB racing make great pumps.
Usually 3" piping on the cold side is easiest and is MORE than enough diameter.
The mallory 4305 is a great FPR. Probably the cheapest "good" 1/2" in/out rising rate regulator out there.make sure to get the one for fuel injection. Think it's an "m".
On the exhaust side of the turbo you want as much heat as possible, heat is energy. The cooler the gasses get before they hit the turbo the less impact they have on it.
Yea, I agree with the numbers game. My engine should make 325 stock at the crank plus a little extra with the external add ons. Its not. I am running about 1 second lower in the 1/4 than it should run. Its tired. Times, trap speed and weight is always how I figure hp numbers.
For the parts, sounds good to me. I was only looking at the one turbo for the ball bearings so it might spool faster. But I like the other turbo for the size that you mentioned. And no, I don't want to spend 2k on one right now. Lets see where I can get with this one first.
As for heat in the pipe. If I run the bed mount, I could always wrap the pipe all the way to the turbo flange to help retain as much heat as possible. Do you think that could help it out a little? I do.
How do you think an air to water cooler would do on the street? I could get all this mounted in the bed and get all the rear weight I can get and all that happens up front is the intake pipe and BOV. If I have to use and Air to Air for the street then I would want to mount it up front for airflow. Which then adds about 5 to 6 feet of added pipe before I get to the TB. I am not sure if the length of the cold side is a big deal or not. I wouldn't think so other than maybe a little added pressure drop/loss.
A2W is also a great idea. They do not require ICE to work well. The water in your IC tank will be around ambient temps. The IC pump that circulates the water is usually run off a boost or WOT switch. So the water only circulates in boost. Just like an A2A uses ambient temp air to cool, the A2W is using ambient water to cool. ICE is just a bonus for track day. I’d suggest a large 1” drain on any tank you run as you will want the ability to drain and fill it quickly at the track. Also Igloo coolers work really well as intercooler water tanks. The typical alum A2W tanks sweat like crazy and make a huge mess.
Cold pipe length and diameter all affect response. Shortest routing is best. Smallest diameter without limiting overall power is best. Anything else is just adding volume to the system. If you went with twins you could use 2” cold side pipes feeding the intercooler. Response would be great. You could feed the IC with 2.5” pipe with a single turbo. Just step it up or down at the coupler as needed. Lots of opinions on the proper cold size piping and how to calculate it. From what I’ve read you size the cold side by NA flow. The turbo only makes the charge more dense. 2.5” will easily support 400hp NA. IMO If you’re not making over 400 crank HP NA using tubing over 2.5” is not beneficial in anyway.
That said...
Taxman, that being said, he sure as hell knows what he's doing. A guy on the Sloppy mechanics facebook page yesterday said he was wanting to run twin 70mm turbos on his junkyard engine and run 30 PSI. His first turbo build BTW. Most people don't understand that there is more to it than throwing on a big turbo, getting a half-assed tune, and running 20+ PSI.
I always suggest making things as universal as possible so that you can change things around later without too much effort. Decide on a turbo flange, T4 or T6, and place it somewhere that will allow you to upgrade or downgrade turbo sizes later. If you make anything too setup specific, you'll find yourself needing to make more difficult changes later on. Keep that in mind when going through all of these ideas.
As for the entire setup. I am already trying to design the system to work at a low psi range for the stock engine with room to add more power when I build the engine to handle the added boost. But I also want to be able to interchange parts like the turbo later. So when its done, it should be able to make swaps pretty easily with little or no modifying.
