symptoms of lifting head?
Old Jun 6, 2004 | 12:19 AM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
I run the MLS 6.0 head gaskets, got the idea from Harlan, my longblock is similar to his setup from a year ago.
Old Jun 6, 2004 | 04:39 AM
1dirtyZ's Avatar
thanks for the info, any idea on the thickness of the MLS gaskets?
Old Jul 22, 2004 | 07:17 PM
Billiumss's Avatar
I'd like to know too...
Old Jul 22, 2004 | 09:03 PM
MYTURBOT/A's Avatar
The rad cap is suppose to be under pressure if it isn't the cooling system won't work right. FYI the 6.0 head gasket thickness is .055 according to GM.
Old Jul 22, 2004 | 10:15 PM
MelloYellow's Avatar
Just had this same problem with Cometic MLS's on my new motor.
They are off and will never touch my car again.
Also had an earlier Cometic failure after 1 year on motor.
They just don't always seal up well.
Am using GM MLS from now on.
Old Jul 22, 2004 | 10:29 PM
MYTURBOT/A's Avatar
When I was getting ready to do my head swap i talked to cometic and they said themselves that they were having sealing problems with there HP gaskets and were working to resolve it. So i went with the stock MLS.
Old Jul 23, 2004 | 02:30 AM
Oops, sorry for saying HP (edited).
My problems were with the Cometic MLS also.
I threw my HP in the trash and they never went on either engine.
Even the Cometic non-HP series have been a nightmare for us lately.
I've never heard of a problem with the GM MLS tho.
Old Jul 23, 2004 | 07:55 AM
1point3liter's Avatar
Off topic of the lifting heads...
If you're hearing ticking up top (possibly detonation), have you tried running race gas to see if it clears up?
Old Jul 23, 2004 | 08:08 AM
stealth's Avatar
Originally Posted by 1dirtyZ
so what are the symptoms of a lifted head?
We've got a master's degree in lifting heads off an LS1. The first and most obvious symptom would be blowing coolant into, and out of, the collant reservoir, and perhaps finding coolant splatter in the engine compartment.
Old Jul 23, 2004 | 02:26 PM
Pressurized Coolant, ie: Coolant Loss, Blowing into Coolant Reservoir, Boiling Radiator Cap, Coolant out exhaust, Popping Freeze Plugs out of your heads (fun).
