Another Derale fuse holder failure
But if the fan runs 25A and your fan will be on a lot, then you absolutely need better wiring setup.
I'd never want a continuous load higher than about 2/3's the rating of the fuse and holder.
And if you want good quality blade fuses, go to a junkyard and get them from a cars original fuse box. Most aftermarket stuff is just cheap chinese *****.
here's a few more choices...
http://www.ebay.com/sch/i.html?_from...clamp&_sacat=0
I wouldn't recommend using the factory wiring.
So far, no issues. But VERY limited time.
