knock on first pull only
Old Jul 22, 2015 | 10:06 AM
ToxicWS6's Avatar
Default knock on first pull only
i have a stock lq4 with a blower cam in it and a 76mm front mount turbo on 12psi, been finishing up the tune on it now and ive made a handfull of highway pulls in it, one thing i cant pin point or figure out is, if i start the car, drive it around get it up to tep, IATs around 95-105F, ECT around 200-210, everything looking good, ill make a WOT pull in 3rd or 4th, and the first pull ill get 1-2 degrees of KR at 1.20g/s (full boost) which i would take as knocking and would need to back off timing, but if i go to make another pull i get clean 0s across the whole KR table, the first "pull of the day" i get 1-2 degees, then i would do 3-6 more pulls right after that one and id get 0degrees every pull till i shut the car off ( maybe also wait awhile of cruising around havnt been out that long though), this has happened 2-3 times, each different days
should i take this as real knock?
running just 93oct and also im only at 11 degrees timing in boost and almost every other lq4 build around 10-14psi are at least 14 degrees, most 16 degrees advance ish area, so i feel my timing is very safe and i shouldn't be getting knock at all but i do on the first pull only it seems
my A/F is right at 11.6-11.8 through all the pulls
when i get on my tuning comp ill try to post tune up and scan
is there anything that could cause this "random" first pull knock? im not 100% comfortable ignoring it yet and not sure where to start looking at that would still cause knock with correct A/F and low timing
i have TR6s gapped at .025 also, worked well on last engine that was a 5.3 on 16psi and 11degrees, never knocked and pulled its *** off so im kinda ignoring it now but if you all think its worth it to pull and inspect plugs i will
Old Jul 22, 2015 | 11:23 AM
97_ek's Avatar
In for answers. What kind of power were you making on the 5.3 at 16psi and 11 degrees? I'm tuning a 4.8 with a 76mm now, and I was thinking I would only be able to go to around 14 lbs or so on 93 before I started experiencing knock.
Old Jul 22, 2015 | 12:14 PM
ToxicWS6's Avatar
Was an lm7 with 243 heads so i had 9:1 CR, same blower cam im runnin now, never made it to dyno but an identical engine with diff brand turbo cam and 17psi put down 804rwhp, ill say this on 315/35r17 nittos i could roll into it 3rd and boost would come on and it blow the tires off, actually a little scary at 80mph lol
Old Jul 22, 2015 | 01:40 PM
97_ek's Avatar
Mine is a 4.8 with 243s, so compression should be a tad below 9 on this one I think. I'm surprised you were able to make that much on just 93, but hopefully I can have the same luck. Did it finally come apart?
Old Jul 22, 2015 | 01:42 PM
ToxicWS6's Avatar
yeah, leaned out when i put in bumper dump and blew up, i had stock rails and fuel lines so it ran them dry, leaned out and boom
Old Jul 22, 2015 | 01:58 PM
97_ek's Avatar
Gotcha. Well hopefully this 4.8 won't have any issues making 600ish. That's all I'm shooting for for now. Thanks for the info. Sorry I couldn't help on your question
