E85 vs 93 vs Spark vs Boost
Old Jul 26, 2015 | 07:28 PM
Higgs Boson's Avatar
Default E85 vs 93 vs Spark vs Boost
What will make more power assuming E85 maxes out the fuel system:
E85 at 9psi and 15 degrees of spark timing
or
93 at 12 psi and however much timing it could take...7 or 8 or whatever.
Basically, if I am fuel capacity limited on E85 (and more fuel is not an option at this time) is it better to stay on E85 or move to 93 for more headroom?
Old Jul 26, 2015 | 08:33 PM
IronBlocked's Avatar
If I were to guess without knowing what turbo, what itnercooling, 93 is gonna take more than 8 degrees without knock
Old Jul 26, 2015 | 09:04 PM
It's hypothetical. Maybe E85 will take more than 15 as well?
Let's call the setup a 416ci that makes 550rwhp NA. We will put on a D1SC or F1A supercharger at 9 or 10 psi and make 715rwhp on E85, whatever the timing. Will I make more power on 93 and more boost/corresponding timing or E85 and less boost/corresponding timing, all else equal?
Remember, E85 will max out the fuel system, 93 still has 30% more headroom for fuel, which I would max out by applying more boost.
Old Jul 27, 2015 | 04:53 AM
HeavyMetl's Avatar
Uhh...I'm running 22* timing at 10psi on E85. Maybe I need to back it off a little, but I have not had an issue. And yes I'm intercooled.
Old Jul 27, 2015 | 06:36 AM
forcd ind's Avatar
I have run 22 on 93 @ 12 lbs boost, spark plugs were #6, good plug reading
Old Jul 27, 2015 | 07:06 AM
This is going on a 12:1 416ci engine..... How much power did you guys put down with those setups?
I am thinking my fuel system (direct injection so no upgrade right now) will be maxed on E85 around 715-725 rwhp..... I am trying to figure out if I will make more or less on 93 since I will have more fuel (and therefore potential for more air) but less resistance to detonation and a hotter combustion temp.
Old Jul 27, 2015 | 08:55 AM
Orr89rocz's Avatar
If its 12.4:1 comp run the e85. I dont see pump gas working well there and if it does it will have to be so low on timing i dont think it will match the e85 output
Old Jul 27, 2015 | 09:03 AM
So does it sound right to just size the head unit according to how much airflow my fuel system will support then?
D1SC or F1A or?? Any recommendations? My only requirement is a self contained head unit.
 Michael S. Palmer
Old Jul 27, 2015 | 10:16 AM
Forcefed86's Avatar
That’s a really high SCR. I wouldn’t trust pump on it NA. Even on E85 you’re pushing it. Either run race gas so your fuel system can keep up, or upgrade the fuel system.
Get the biggest blower your class allows. It will heat the air charge the least per pound.
Old Jul 27, 2015 | 10:43 AM
This is just a street car, for fun. There are no upgrades to the DI fuel systems available yet, which is why that's a constraint. I am going to use a high pressure pump from a Z06 and a lash cap to get it to open more, Z06 injectors, and command more rail fuel pressure to get the most out of it, I just don't know where I will be at the end.
Old Jul 27, 2015 | 12:26 PM
cmiller8006's Avatar
What are we working on? There are a lot of things that can be done tune wise with E85 to get further. I was on stock pump, stock cams, stock di injectors in my cobalt at 500 whp. However that was only 110 oct. On the same set up with e85 I could only manage in the 430 whp range we figured, never dynoed that set up.
Old Jul 27, 2015 | 12:41 PM
toytech93's Avatar
12:1 + boost is going to be extremely hard to do with a weak fuel system. 116 fuel might be your only saving grace.
Old Jul 27, 2015 | 12:49 PM
Direct injection 416ci small cam C7 with all supporting mods, 12:1 compression, long tubes, worked heads, etc. Direct injection really mitigates concerns over compression.
Going to add either a D1SC or F1A. Not sure if I should run 93 or E85 or something in between because I can't just add aftermarket fuel system parts as there are none available.
My stock fuel system is basically maxed on E85 NA at 550 whp. I can swap for the Z06 HPFP and a lash cap, injectors and pick up about 30-35% more fuel. regardless of what blower I run, I am going to do this anyways. So does that give me 30% more air flow capability or 30% more horsepower capability? Because that would be 715rwhp.
Or will I make more power with 93 octane because I will have a lot more fuel available?
DI boosted motors are safe in the 12.25 - 12.5 range. Just not sure about the blower choice and spark timing differences.
It's been recommended to run a mix around E50 and I will get 90% of the E85 gains and still retain fuel headroom....
Ideal goal is around 850 rwhp if I have the fuel for it. It's either 93 or E85 or something in between.....no race gas, no meth system. This is a street car.
Otherwise, if it's a total lost cause, I will just spray it but that's such a pita.
Old Jul 27, 2015 | 03:32 PM
Mix race gas when going to the track, e85 is just gonna take your power away and straight 93 is gonna knock your motor to bits
Old Jul 27, 2015 | 04:41 PM
The only time I drive it is in anger. It's not a daily driver or a track car. More of a hooligan car.....
It sounds like maybe a blower is not the right thing for this one.
Old Jul 27, 2015 | 05:07 PM
NicD's Avatar
7 Second Club
DI doesn't get rid of the octane concerns at all. Sure it helps but it will still be very evident you are going to be severely octane limited on pump. This motor sounds like it's not even built yet, why are you going so high on the compression with boost?
I've tuned a bunch of supercharged C7s at this point and the ones with lower compression are MUCH happier with limited octane and make more power in the process.
Old Jul 27, 2015 | 05:25 PM
sounds like doesn't always equal is.
criteria is laid out, whats the answer. "Don't boost it" is a completely valid and acceptable answer.
Old Jul 27, 2015 | 06:32 PM
SLOW SEDAN's Avatar
Since when does a $470 meth kit make it not a street car? Lots of people run meth kits in daily driven cars with 700+whp on pump gas. Doesn't even sound like yours is a daily driver and even in a daily driven boosted every day a 3 gal meth tank usually lasts at least two tanks of fuel so its minimal maintenance to top it off.
Fill this up with M1 and problem solved, plus it helps crutch your crippled fuel system.
http://www.alcoholinjectionsystems.c...roducts_id=101
Old Jul 27, 2015 | 07:56 PM
I agree with him, looks like meth injection is your savior if you're dailying this car
Old Jul 27, 2015 | 09:17 PM
You quoted me saying it is not a daily driver, so you are correct when you say it doesn't sound like it's a daily driver. ;-)
I don't want to add meth or a boost a pump, etc. I am ok replacing parts but I do not want to add anything to the "system." I didn't mean to imply a meth system makes it "not a street car." The sentences are next to each other in my post, thats all.
Is it ok if we move on? What will be the best blower for this motor between an F1A and the D1SC?
