oil on spark plugs causing misfire.
its a 08 l76 with 317 heads.
btr springs retainers and valve seals
tick turbo cam
br7ef plugs at stock gap
i have breathers on the 2 rear valve cover ports. and the valley cover port running into the tb.
compression test was held for 2-3 seconds per cylinder
took pics of all the exhaust ports. all look similar except for #7
i can take any pics you need to further help. i appreciate all feedback
thanks!
The plugs dont look that oily...but certainly they do look fouled, your tune could need work there.
But re-circulating any crankcase breathers into the inlet is asking for oil to get ingested unless you have very effective oil/air separation prior to routing it back to the inlet.
