I am back in another C5, of course with a blower
Old Aug 20, 2015 | 08:41 PM
1bdbrd's Avatar
Man I love this build especially because its a car I will be able to see out and about around KC. I loved your old white FRC and really wished I could have bought it.
Old Aug 21, 2015 | 07:03 AM
b16gsr's Avatar
Thank you. That was a good car.
Got some work done last night. Driverside manifold and cat installed, passenger side being a little trying with the O2 location and the SFI bellhousing and the starter location. I will work through it.
Studs installed:
If you ever wanted a cheap O2 plug, $2.79 at the auto parts store.
Like a glove.
Cleaned up the wiring and the trans cooler lines.
Driver side hung and done.
Ordered a vacuum manifold and a set of 2.5" v-bands thanks to my homie Jamie for the suggestion for hanging the exhaust.
Old Aug 21, 2015 | 07:42 AM
LQ4-E39's Avatar
Thanks for documenting the C6 Z06 manifold swap, it seems like a popular alternative to longtubes. Also, are those stock Ti mufflers you installed? Should sound awesome. Love the Electron Blue.
Old Aug 21, 2015 | 08:32 AM
b16gsr's Avatar
You bet, I had this same exhaust combo on my last FRC. I am uploading videos.
Yes those are OEM Ti mufflers.
Old Aug 21, 2015 | 11:03 AM
b16gsr's Avatar
Someone had asked for a clip of the C6Z manifolds with headers and the stock Ti mufflers.
Here is my last FRC with them:
And here is the new car with the TSP catted headers and and the stock Ti mufflers. I am looking forward to see how the new setup sounds.
Old Aug 25, 2015 | 05:36 PM
b16gsr's Avatar
Got the 2.5" V-bands for the exhaust with a quickness, nice quality for $15 each.
Worked through the kinks of the exhaust and got everything installed.
Picked up these 3" to 2.5" transitions to mate to the factory mufflers.
Buttoned up the topside minus the alternator and some other wiring.
Moving on into the interior......
Old Aug 26, 2015 | 05:58 PM
Sales@Tick's Avatar
I take that this is Preston's old car Nick?
Old Aug 26, 2015 | 07:06 PM
b16gsr's Avatar
Default I am back in another C5, of course with a blower
No sir came out of Oklahoma. I was going to have you build a cam but I am not cracking a gasket on this one to see how it goes. If it changes you will know.
Old Aug 29, 2015 | 09:15 AM
b16gsr's Avatar
Getting closer everyday. Been waiting on the cradle to ship from ECS for 3 weeks. I have just about buttoned up the engine bay besides all the new hard piping and covering the power wire for the alternator with loom. Going to find a set of fuel rail covers to see if they will go back on.
Old Aug 30, 2015 | 09:19 AM
b16gsr's Avatar
Sold the black OEM wheels, as I wanted a set of charcoal OEMs and came across these off of a 5800 mile 04Z. Spent some time cleaning them back up. They are like new, it is insane.
I have a set of Nittos that I will throw on them next week.
Old Sep 1, 2015 | 07:37 PM
b16gsr's Avatar
New front tires arrived today, got the shop to put them on. Rears should be here Thursday AM I am hoping. These wheels are in perfect shape, minus a couple little bruises.
Going to hang the new gauges and pod tonight. Just finished the oil change.
Old Sep 2, 2015 | 09:29 AM
  #32
b16gsr's Avatar
Got the gauges wired up(have to connect power) and installed. This pod did not fit the car well at all but I made it work.
Started with this:
Ended like this:
Still have a lot of clean up to do.
Pod trimming:
Installed:
Old Sep 2, 2015 | 09:49 AM
  #33
LQ4-E39's Avatar
those wheels look outstanding.
did you ever end up mating the transitions to the factory mufflers?
Old Sep 2, 2015 | 10:48 AM
  #34
b16gsr's Avatar
Thank you, they are just what I wanted.
I will be having all the welding done next week.
Old Sep 3, 2015 | 09:07 AM
  #35
b16gsr's Avatar
Worked late into the night and got a significant portion done. I will say it is alive.
This was the transmission controller wiring underneath the passenger seat:
This is what I did. Everything was cut trimmed and loomed, then tucked in properly.
Got the ALKY control and vacuum block all finished up and tied back.
Also the replacement cradle from ECS arrived:
Called it quits about then:
Headed to fab work next week.
Quick video:
Old Sep 9, 2015 | 11:08 PM
  #36
b16gsr's Avatar
Got the tires mounted and balanced today. We have been busy at work so played catch up from a long weekend yesterday.
They are beefy.
Sat the car back down on all 4s as well. Damn it's dirty.
Picked up a fresh set of plugs and wires as well and threw them on. The shorter ls3 wires I had just didn't fit well and I wanted to use my header boots.
Also finished up all the interior wiring and put the interior all back together so it looks like a car again. I will snap some pics tomorrow.
Old Sep 12, 2015 | 10:50 AM
  #37
b16gsr's Avatar
Went underneath and was doing some inspection, and found this....
Luckily I was able to find the proper bolt at the local Hardware store. Could have been a huge issue.
Got the new cradle installed, have some work to do to make all the catch cans and trans cooler mounted.
Old
Old versus new
Old Sep 13, 2015 | 08:04 AM
  #38
b16gsr's Avatar
Picked up a set of these for the radiator mounts, as the OEM ones are stupid expensive and Amazon had these for $22.
Old Sep 14, 2015 | 08:04 PM
  #39
venom ws7's Avatar
Great work man Congrats ...
Old Sep 15, 2015 | 10:58 PM
  #40
b16gsr's Avatar
Thank you.
Got some loose ends tied up and it is ready to go to fabricator. I am dropping it tomorrow. Don't mind the dirty mess it hasn't seen the light of day in 5 weeks.
All that is left is the fab work, spindles and welds, tuning and alignment. I have a couple cosmetic things to do one being the removal of the clear bra mess and then a full polish. My body guy is fixing a hole in the lower rear bumper now.
