990hp,s484 dyno video!
Old Oct 16, 2015 | 03:45 AM
SirNemesis's Avatar
I didn't even know you could get a 96mm turbine in a T4 housing. This is excellent! Good job, great results.
Old Oct 16, 2015 | 07:13 PM
a-low's Avatar
Congrats man. Did you brace the crossover? Got any pics?
Old Oct 16, 2015 | 07:24 PM
T.Fiddler's Avatar
WOW
Nice
Old Oct 18, 2015 | 06:46 AM
Superman09's Avatar
LS1Tech Sponsor
Awesome! Great work!!!
Jon
__________________
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
Old Oct 18, 2015 | 11:15 AM
coltboostin's Avatar
If you where blowing out spark it would likley show up on the graph.
Old Oct 18, 2015 | 12:36 PM
Kmspeedie's Avatar
your radiator stood up? and is it the non a/c kit? AWESOME numbers man badasss
Old Oct 18, 2015 | 07:18 PM
vettewreck's Avatar
Originally Posted by DavidBoren
Two questions for you.
Is it fast? Dyno numbers don't mean ****.
No it's not. 990hp is never fast.
Old Oct 18, 2015 | 09:07 PM
ujslost2's Avatar
Yes it is. Power flat lines up top on the pulls. And noses over. Can see it on the graph. I changed a couple things. Going to go back in the next couple weeks and see if it fixes it.
Old Oct 18, 2015 | 09:08 PM
ujslost2's Avatar
No radiator is in stock location. And yes it's the non-AC v1 kit. I added a engine bay pic to first page. Appreciate it!
Old Oct 19, 2015 | 07:24 AM
vinceI's Avatar
Originally Posted by ujslost2
Not bummed at all! Just want to make sure I'm not leaving anything on the table, and want the car to be right. Dyno graph shows something to be up.
Will try to take muffler off and check that next time. It turns down even with the passenger side door. So it's not "full" exhaust.
My initial thinking is I may be blowing out the spark. Had the plugs gapped to .028. Gonna tighten them up some and see if that helps. Ngk b8efs
I have seen 50hp opening the dump on a grand national. Also have run as low as .018 gap at those boost levels. Do you have an intercooler? If not what kind of iat are you seeing? Did you check back pressure? Just throwing out some ideas but nice numbers so far.
Old Oct 19, 2015 | 08:30 AM
ujslost2's Avatar
Yes, I regapped the plugs to .018. They were on .028. I think it will help. Yes I have a intercooler. Iats were around 104-105 on dyno. Haven't checked back pressure yet. But will be. Gonna try without the muffler next time also. Appreciate the help
Old Oct 19, 2015 | 10:03 AM
  #32
vinceI's Avatar
No problem. Hope it was just the gap and not a back pressure problem. Looking forward to more numbers. Is it a typo or are you running 245 heads on a small bore? Thought they were recomended for a 4.155 or bigger bore.
