rear mount turbo
My best advice is to read all of the problems that accompany a rear mount. I'm hard headed and thought I had the oil issue taken care of with a Comp oil less turbo and the slow spool fixed with a spool valve. It helped, but the exact same turbo made 5 psi more boost as the front mount. This can be successful, you will have to be ready to solve issues that aren't "common" per say. You will become your own expert. Best of luck!
It worked well. Used an on3 t70 .96 ar at the moment. Spool was good thru stock manifolds, stock cat and stock 2.25" exhaust pipe. I gutted cat and lost spool. The cat helped retain heat and smooth flow. I am gonna make a bypass pipe and wrap it all to see if i can get it back. It was making 2psi part throttle at 2200-2400 before.
Makes as much as i dial in. 7 psi gates up to 15 so far. Runs like turd still as i think it may be weak ignition. Gonna try regapped plugs and retune. But a 305 isnt strong to begin with.
I have some oil leaks thru the turbine for some reason at times but not sure if its due to steep driveway and hills i climb occassionally and oil not draining well or what. Normally driving its been fine
Do use a manifold and go small on exhaust pipe. 2.25-2.5 max. Wrap it and it will be great
