Best stroker kit with strength and power
I just think it's stupid to run a big stroke in a standard deck LS block on a turbo car. You give up alot, and what for
The hole lack of TQ thing doesn't make sence. If you can get on the turbo, there is more TQ than u ever need available
Those heads in a 364-370" lq4 in your sig?
Whats the compression and what cam? Could be combination of being under compressioned for the setup, heads could be too big and have slow air speed, converter not right for the cam/turbine size, turbine too big, turbine housing too big, not enough heat wrap to keep energy in the system.
This is one of those scenarios where you compromise street vs track. Its not hard to spool big turbos on the brake with the right tricks. Theres a 281" v6 buick guy spooling a 91 mm that way. But from a roll on the street when you wanna have some fun, does it spool at all? Is it laggy? Cubes help here in a sense since each revolution displaces more exhaust volume, there should be more drive energy when you need it. Also turbine housing sized on the smaller side should help at expense of high rpm power production
I would try those things before changing motor out. And yes some lag is to be expected when looking for big top end power. Given lack of housing options available for alot of turbos its hard to dial in a sweet spot for spool vs power sometimes.
Also perhaps alittle looser stall to help get some rpm. More timing around stall point and 1-3 psi range to help hit converter harder to spool turbo? Little things to try
What advantage is there to running a taller/heavier piston with a lower rod ratio?
