PVC clearance
Old Oct 31, 2015 | 08:17 PM
vht's Avatar
vht
Default PVC clearance
How much lift can you run without getting into trouble on the 6.0? I have a 06 truck motor. I'll ck it when I degree the cam, but I was just curious. Also, when you degree the cam on the LS, what do you use for a lifter? On a BB or SB I use a solid lifter.
Old Oct 31, 2015 | 11:25 PM
elkydragger's Avatar
I made my own solid lifters by adding washers inside. It is a must for checking PTVC
