bent rods again
Injectors are the standard ev6 siemen deka 80s.
The meth kit is a 50/50 mix with a single #6 nozzle. I think snow said rated at 600hp. **** i was planning on adding another nozzle to it.
Hear is the deal. I was running 5psi boost steadt with jgs 50mm gate. Line hooked to.bottom. i hooked to top and got steady 20psi boost. I made 4 good hits at that level no.issues. tune looked good no knock, 11.5afr.
Well the next day i drove it and banged limiter 3 times and bent 7 & 8 pretty bad. I did pick up 4° knock while on limiter which may have hurt it as well. Im puzzled between getting another set of gen4 rods or h beams. I would hate to turn it down. Its makes some serious power at 20psi.
Im also gonna try maybe straight meth instead. My treadstone intercooler does its job with iat temps. Damn let me get this thing together and give it another shot the correct.way. thanks guys.
HPTuners>Engine>Cutoff, DFCO>Fuel Cutoff RPM vs. Gear>then set the resume to a lot lower RPM.
I set my cutoff to 6,500 and then my resume to 4,500. Then I don't worry about banging off the limiter. If I hit the limiter I just let out. Helps while working on getting my 4l80E to shift at the correct RPM.
John
If you have a 2 bar map, the tune is gonna flat line at 14.7 lbs. Hard to believe your AFR stayed steady at 20lbs with a 2 bar map. That woudl mean teh engein was using the same amount of fuel at 14.7 as it was at 20.
