boosted ls cylinder head questions....
Old Nov 6, 2015 | 10:40 PM
chevyracer8262's Avatar
Default boosted ls cylinder head questions....
I'm building my first twin turbo ls starting with a gen 3 5.3 stock bottom end with arp studs and arp2000 rod bolts, New clevite bearings, New rings gaped for boost and a custom cam from cam motion, twin s366 turbos w/ air to air cooler and water meth injection. But my real questions come with the heads I got a killer deal on a pair of 243 heads with 2.02/1.57 valves. I've started bending and polishing the chambers but would it benefit a boosted engine to port the heads like you would for a n/a motor or just leave them as cast? Also would it be beficial to blend/port the flipped exhaust manifolds to help the flow better?
Old Nov 7, 2015 | 11:44 AM
RonSSNova's Avatar
You can work the bowls pretty easily. It would be good especially since they have bigger valves installed. As long as you have some porting experience.
In the few manifolds I'VE had my hands on, the ports are larger than the head ports. So really nothing to do there.
