How necessary is new gasket and studs?
Old Nov 30, 2015 | 04:42 PM
bh10's Avatar
Default How necessary is new gasket and studs?
Starting my turbo build, 75mm s400 on a LQ4. How necessary is LS9 head gaskets and head studs? What's the limit for stock bolts and head gasket?
Old Nov 30, 2015 | 06:16 PM
RoidedSS's Avatar
more or less depends on the how far you want to take the build. If you're looking to do it on the cheap and run less than 10 pounds, I wouldn't personally be too concerned. If you plan to lean on it more and more, I would take a little precaution and build it a little "stronger" if you have it apart.
Old Nov 30, 2015 | 06:19 PM
lmt0705's Avatar
Cheap insurance
Old Nov 30, 2015 | 06:50 PM
IronBlocked's Avatar
ls9 gasket not so much, could get away with the stocker, but the studs I'd do no matter what
