Waste gate question...
Old Dec 31, 2015 | 11:08 AM
red fury's Avatar
Default Waste gate question...
I am putting together a single front mount setup on my car. 347ci, 11.1 cr, cxracing hotside... what size waste gate are you running with similar setups? Going to run 10-12 psi
Old Dec 31, 2015 | 12:52 PM
bigredd's Avatar
Not enough info really but i suggest as big as possible. Need to know what turbo at a minimum though. If it were me i wouldnt go smaller than a 46mm
Old Dec 31, 2015 | 01:10 PM
red fury's Avatar
on3 78/76 t4, .96 exhaust
Old Dec 31, 2015 | 02:03 PM
kingtal0n's Avatar
The smaller gates are better for higher boost. If you ever want 19-30psi you will probably want a smaller gate.
for 10-12psi I would buy a 10psi spring and use a boost controller to get 10-15~ easily, total boost pressure.
Old Dec 31, 2015 | 03:09 PM
red fury's Avatar
So like a 50mm with a 10psi spring would be a good start?
Old Jan 1, 2016 | 07:08 AM
alocker's Avatar
Sure. My JGS 500R nets about 8psi on the heavy spring in a very mild 6.0.
