Twins or single?? LY6 600hp goal
The big single pulls hard once it gets going, but because of my converter (PTC) it's hard to get it going. From what I've read the converter is hard to get right with the 4L80's and retain the lock up feature. I also swapped out the cam (which I think helped a lot too).
If I were to go back with twins, they would be larger (at least on the exhaust side).
I like your sig about PTC, so true.
It is entirely dependent on how much flow you can have at what pressure ratio at what RPM.
Here's the thing, on a stock 6.0, yeah a set of twin 57/58mm comps would do fine if say limited to 5,500RPM. But throw in a bigger cam & rev to 6500 & those turbos could start blowing hot air at 80lb/min. That doesn't leave a lot of headroom for growth later, but it's up to the end user.
Thanks 408!
I was told to turn mine hard from the previous cam grinder I had, but on SBE stuff I think it's best to keep the rpm low. I would talk to JFR (Stock48) about a cam, and maybe call Viren at VS racing to ask him about turbo selections.
I would go with Circle D or Yank if it's a 4L80e. Might want to get the triple disc so you can lock it under boost.
408GT Nice! What track do you usually go to? Yeah its a 4l80e.. Ive gone a ton of different directions with this build since I'm learning a ton in the process.. but I'm going back to the ly6/4l80e harness and Im wondering how I'm going to incorporate the TCU into my 95 camaro.. Ive built a standalone DBC harness for it and had the DBC throttle body to convert it but long story short I'm going back to the original harness with DBW..
If your turbos spool faster than that, then go for a converter that is better matched to them. For a street car, it's usually best to get the lowest stall that still puts you above the boost threshold RPM. Gives a good balance between manners and performance.
j
Just went PT88 dual pumps and 1000cc injectors and bigger cam, waiting to finish it up
80#'s would be fine on the injectors.
