Help! Oil leak at hotpipe/wastegate
Old Feb 11, 2016 | 11:59 AM
nlpy8b's Avatar
Exclamation Help! Oil leak at hotpipe/wastegate
Finally got my project running and I have a smokeshow...but not the good kind.
I'm getting oil spray and residue out the hotpipe to wastegate band.
Oil pressure at idle is 55psi. I bought some vibrant restrictors for the feed line 3an, but I don't think that explains oil in the uppipe...could there be a motor problem with blowby?
Attached Thumbnails Help!  Oil leak at hotpipe/wastegate-20160211_115039.jpg
Old Feb 11, 2016 | 12:03 PM
svslow's Avatar
So the v-band is leaking oil?
Old Feb 11, 2016 | 04:20 PM
nlpy8b's Avatar
Yes, it's leaking at the wastegate vband. My plan is to install the vibrant oil restrictors, remove the waste gates and try to reseal with copper RTV (good idea?), and temporarily remove the stock style pvc setup to determine if crankcase pressure is a contributing factor.
Any other ideas or alternatives?
Old Feb 11, 2016 | 04:38 PM
a4ls2goat's Avatar
If the stock style pvc system is still hooked up, that can be an issue
Old Feb 11, 2016 | 08:36 PM
nlpy8b's Avatar
I have a pair of fabricated aluminum valve covers...was considering installing a breather in each aND deleting the stock valve covers and pvc pictured in the original post, thoughts?
Old Feb 12, 2016 | 11:54 AM
nlpy8b's Avatar
So I took off the wastegate on the driver's side. It is mounted directly on my flipped up and forward truck manifold.
When you look down in the exhaust manifold there is a puddle of thick black oil sitting in the manifold! This oil is supposed to be brand new with 0.1 miles.......what is going on?
Old Feb 13, 2016 | 07:45 AM
Old Geezer's Avatar
Cook fresh oil, and that's what you may get..
As for the location, I'd suggest you check the turbine hsg, and see if the oil is running back down into the manifold.
If not, only a couple other sources it can come from.
1.valve guides.
2. rings....crankcase back psi...stock pcv fail.
Old Feb 13, 2016 | 01:06 PM
stevieturbo's Avatar
Are you saying that even after a drive there is visible liquid oil coming out somewhere ?
55psi oil pressure at idle is a lot, how much is it at higher rpm ?
What is your oil drain like ?
Crankcase breathers ?
Old Feb 13, 2016 | 06:09 PM
nlpy8b's Avatar
Thanks for the input old geezer.
Stevie,
It's a brand new setup, no drives yet. Only fired up ling enough to detect the problem.
Yes 55psi at idle with Thompson ls3 and their melling pump. It's still on the gmpp 525 ecu tune so no higher rpms than idle yet, it stumbles with throttle. Was hoping to get it idling, up to temp to check out all the systems then head to the tuner for a baseline tune to get the 500mile breaking going.
Oil drains are as prescribed by comp 1/2in to 45 degree 10an fittings straight down in pan.
Currently the pvc is setup similar to stock ls3 with stock valve covers. Driver valve cover tied to driver turbo intake, passenger valve cover tied into intake just behind TB.
I have a set of fabbed sheet metal covers and was considering pushing a trick flow valve breather 1 inch opening in each cover?
Old Feb 13, 2016 | 06:28 PM
Oil pressure is high..but not necessarily a problem.
What size feed lines to the turbos ?
1/2" drain sounds small if that's what you are saying ?
You could try removing the oil filler cap to see if it changes, as that would definitely give the crankcase adequate breathing if the current setup does not
BB or oil journal ?
Old Feb 13, 2016 | 08:49 PM
nlpy8b's Avatar
Comp recommends -3 and 1/2" for their billet triple ball bearing turbos.
Mine is -4 tee'd to equal length -3an lines to each turbo.
Thanks, I'll try the filler cap idea too. Won't that make a serious mess?
Old Feb 14, 2016 | 03:36 AM
Dont drive it with the cap off, just let it idle
A lot of BB turbos only need a tiny tiny amount of oil. Most these days have a restrictor built into the oil feed on the core, but some dont. This can be less than 1mm sometimes.
But removing the filler cap will test the crankcase breathing aspect. If the oil smoke clears up after running with the cap off for a while, then your crankcase breathing system is inadequate.
Really there are only 3 universal things that cause the turbo to burn or pass oil.
1 Inadequate oil drain
2 Blocked crankcase breathers, which essentially prevent the oil from draining correctly from the turbo so is almost same as 1
3 Excessive oil supply/pressure.
Old Feb 15, 2016 | 08:13 PM
nlpy8b's Avatar
I worked on it a bit this afternoon.
Cleaned out hotside, inserted restrictor to -3 feed, found very slight kink in 5/8in ID drain tube (corrected), restarted.
It appeared as though the oil was going to burn off and disappear but after 1min the smoking began to increase and the oil start droping out the down pipe at the firewall.
I remove the wastegate and turbo. The turbine was saturated, up pipe saturated to the first primary but the rest of manifold clean. I now believe ive confirmed the turbo is leaking and its not the motor.
Pulled the turbine of the turbo, turbine is saturated. Im a newbie to turbos but was expecting a gasket to be smashed between the turbine and center cartidge...there is not... so I'm not sure what/how to inspect the assembly
Old Feb 16, 2016 | 06:05 AM
Undo the oil drain and run the engine briefly to see if oil is coming out freely.
Not for too long as obviously this oil isn't goin back into the engine during the test.
Old Feb 16, 2016 | 06:20 AM
alocker's Avatar
The kinked return might have been enough to blow the seal. I'm pretty sure you have to send it into get that shaft seals replaced.
Old Feb 16, 2016 | 06:45 AM
There are no oil seals to blow.
Old Feb 16, 2016 | 04:03 PM
nlpy8b's Avatar
Stevie, Oil is running through the drain. I don't know how I would know how well or not well its draining...but it is draining.
After a long talk with Comp-
1) they don't like vibrant's restrictors and had me purchase their smaller 0.018 filtered restrictors
2) they'd rather me run a distribution block at the motor and two separate -3 lines all the way to the to the turbo. They also recommended running 3an all the way instead of starting with 4an...which I had already done and replaced with the 4an due to someone's recommendation there.
Experience is what it is...but I don't understand a few things...if it's a volume/pressure issue, then why wouldn't the passenger side have started leaking after I added a restrictors to the driver's. Wouldn't the pressure have followed the path of least resistance and blown the passenger side? Also, what difference would it make to tee the feeds off at a distribution block at the motor vs teeing them off my 4an line?
So, I'm going to wait for the new restrictors....and we'll see.
Old Feb 16, 2016 | 04:54 PM
I really dont understand their thinking with the distribution block or -3 vs -4 lines. If you have a restrictor at the turbo...line size will hardly matter
Hell, I have a -8 takeoff from my remote oil filter, through a check valve then tee into a pair of -6 lines to each turbo.
I did chicken out with the -6 and reduced it to -4 at the turbo inlet though even though turbo supplier said to keep a full -6 to each turbo ( BW )
Once I got the scavenge setup working, no issues at all with oil control.
Turbo oiling is very very simple. They basically rely on the drain always getting rid of more oil than you can pump in. There are oil slingers that rely on the rotation of the shaft to keep oil away from either turbine or compressor side.
The "seal" people talk about is a piston ring design, and intended to keep either boost pressure or turbine pressure out of the core, it is not an oil seal.
Well covered here
http://www.yellowbullet.com/forum/sh...618&highlight=
Old Feb 18, 2016 | 05:44 PM
nlpy8b's Avatar
Well, I've come full circle...now I think it is coming from the motor.
While waiting on the restrictors from comp I began working on other things. This lead to an inspection of my ls3 intake which has a big puddle of oil in the back 1/3 (it's sitting back 3 degrees). Keep in mind the entire hotside is clean and only the intake manifold and driver's hotside is wet.
So...I'm going to remove and clean the intake mamifold, remove and inspect the plugs, remove the valve covers and look for damage.
Any other suggestions?
Old Feb 18, 2016 | 09:28 PM
nlpy8b's Avatar
Can someone checkout my PVC setup in the picture in the first post.
Motor is a Thompson stocked ls3.
Valley plate is l92 with no valley port.
Passenger valve cover is tied to I take manifold just under the MAP sensor.
Driver's valve cover is ran with hardline up to the driver's side turbo intake.
