Back to the dyno for some better numbers. How'd I do?
Old Feb 24, 2016 | 11:51 AM
gtfoxy's Avatar
What AR are the turbine housings?
Are those raw or corrected numbers?
Old Feb 24, 2016 | 12:12 PM
BOOSTAT4500's Avatar
.68 A/R. I'm sure corrected. I'll see if I can get the raw numbers.
Old Feb 24, 2016 | 02:50 PM
coltboostin's Avatar
I made similar numbers with similar sized turbos at 22psi on a 5.7L and I was ridiculed for having "BS" dyno numbers LOL.
Great work!!! Should work great at the track
Old Feb 24, 2016 | 03:25 PM
Forcefed86's Avatar
Claiming 872whp @ 21lbs on a bone stock ls1 ,including the OEM cam (Which was your original claim.) Isn't the same thing as claiming 860 on a cam’d 6.0 @ 20lbs. I admit I was being kind and gave up on bashing dyno posts. They are what they are…
FWIW trapping 142 @ 3350lbs going by weight and trap speed comes out to about 740hp. These calculators calculate crank HP. Drop 12% for drive train losses and you are looking at around 652whp to put 3350lbs at a 142 trap speed. It doesn’t take 850+whp to hit 140 traps at that weight. But if we get 100 dyno guys claiming that it does… so be it, I’m tired of arguing with them.
Old Feb 24, 2016 | 03:33 PM
SwampWS6's Avatar
Originally Posted by BOOSTAT4500
On the dyno it went positive at 3600 and peaked at about 6100. Basically kept building through the whole pull. Haven't done a full 3rd gear pull on the street to see if it's any different. The top of 3rd is almost 160mph, so not real anxious to go to jail.
Under normal driving, you can't really tell it's turbocharged.
The cam is 221/225 .622/.621 115+3
That cam tho, Im LT1 and that cam is slightly smaller than mine on my 383 setup. If I can put out similar numbers, I'd be crazy happy!
Keep up the good work and report back with Track Numbers!
Old Feb 24, 2016 | 08:19 PM
A cam would not have helped my total power output as I was out of fuel. It would have only givem me the potential to make the same power with less boost. Wouldn't you agree?
And to clarify I trapped 146mph at 18psi. I made 740whp @16psi.
From where I am sitting, that math still works out great.
Old Feb 24, 2016 | 08:35 PM
Martin Smallwood's Avatar
I had forgotten that this was a high density altitude combination. Definitely would go mid 8's or faster at sea level! At altitude I think your goals are still attainable.
Hope you enjoy it!
Old Feb 24, 2016 | 08:39 PM
The reason the cam is smaller is because he races at 5000-7000' DA. At that kind of density altitude the amount of available air mass is much less than it is at sea level. I use an earlier intake closing event and a later exhaust opening event combined with less overlap because of the altitude.
His cylinder pressure at 5000-7000' DA is much less than the same combination at sea level would be. This necessitates a smaller camshaft to work with the amount of cylinder pressure and effective compression ratio of his engine at altitude.
If it were at sea level it would be several degrees larger and have a little more overlap.
Old Feb 24, 2016 | 10:53 PM
gtfoxy's Avatar
How much is he leaving on the table when he goes to sea level vs a more appropriately sized cam?
Old Feb 25, 2016 | 10:50 AM
SwampWS6's Avatar
Thanks for explaining. I am in St. Louis so I know there is a huge altitude difference in where he is and where I am....
Old Feb 25, 2016 | 12:05 PM
Forcefed86's Avatar
You’re inability to fuel the engine has nothing to do with what is or isn’t possible as far as power output goes per pound of boost on a factory engine. Your original numbers were less than believable, which is why you were “ridiculed for having "BS" dyno numbers”. That’s all there is to it.
It is still listed this way on the SBE dyno top ten dyno list. And 890 was the claimed uncorrected numbers I believe...
https://ls1tech.com/forums/forced-in...end-lsx-s.html
8)coltboostin 872 whp@21psi Twin Billet 67mm (on3) Bone Stock LS1
Old Feb 25, 2016 | 03:04 PM
  #32
I really can't say as I don't have exact data on that type of scenario, but if I were to estimate I would say 25-40hp.
Old Feb 25, 2016 | 06:40 PM
  #33
gtfoxy's Avatar
Thanks, Martin. I appreciate it.
Old Feb 25, 2016 | 08:29 PM
  #34
Less than believable, but replicated by many (including the OP)? I guess everyone is full of ****!
Fuel is fuel. If I only have fuel for a safe 850 HP worth of airflow, a cam or lack there of is not going to magically change that-it will only change what RPM and with what intake back pressure (boost) I run out of fuel at-but it would still be making about the same power. The only confusion was caused admittedly caused by me because the boost numbers I quoted where low. Max boost on the log was almost 24psi on the map. My boost gauge reads 2-3psi low evidently.
870 was uncorrected. The list should reflect that. If not, I will edit it. I will be sure to log boost on the dyno next time.
Old Feb 25, 2016 | 08:56 PM
  #35
I promised a full car shot, so here it is. Nothing special.
Also, have a question for Martin and some of the other more experienced turbo guys here. My peak torque is lower than I expected compared with HP, and much, much higher in the RPM range. What factors tend to cause this? Is it tune related or more to do with the combo?
Old Feb 25, 2016 | 09:39 PM
  #36
gtfoxy's Avatar
Boost response.
It sounds like your boost curve is more like a blower than a responsive turbo set-up. If you aren't reaching max PMP ~2,000RPM before redline then you are leaving a lot of power on the table.
I looked at the dyno sheet & from what I saw I had a feeling it was responding the way you said. That's why I asked, but I didn't want to say anything if you are happy with it.
Converter can have a big impact there as well as other factors. Dyno loading could be one of them if it responds differently on the street. If it reacts differently then ignore the dyno numbers & just move on.
Old Feb 26, 2016 | 03:20 AM
  #37
GTfoxy is dead on.
Was the converter flashing around 5300-5400rpm?
Where was peak boost made?
My car with a 370" and a S476 V2 compressor wheel and T6 1.32 96mm exhaust arrangement made 1080rwhp and 970rwtq. Peak torque was @5700-5800rpm, but the converter was flashing right around that rpm as well. I think it would of shown more torque had the converter been able to grab the engine earlier around 5300-5500.
I see this somewhat often with turbo engines unless it's on a mustang dyno with appropriate load.
Old Feb 26, 2016 | 04:12 AM
  #38
gtfoxy's Avatar
He said max boost was at 6,100RPM on the dyno(last post pg1).
If it responds the same on the street, & his shift recoveries are where they should be then it could be tune related. I don't know how they should respond as I have not tried this combo, but I was thinking given his combo with .69 A/R's, ~5,000RPM would be where I would have guessed it would be, but again haven't been there personally & I don't know how much the altitude would effect it.
One thing though is if it does act like this & nothing is really whack, it will be easier on engine internals. Won't ET the same as if it had better response, but it will MPH about the same.
For me OP, personally, I always shoot for a combo that yields max boost at the shift recovery RPM of @ a miminum a few 100RPM before. This ensures you have max torque available at the recovery RPM & helps keep the car accelerating harder rather than having to ramp back up on boost. Ensures you get that warped 9-iron to the forehead & the hand around your spine pulling you back in the seat feeling when you grab the next gear.
Traction is a limiting factor here & everyone has their own preferences based on their needs, wants & racing style.
Old Feb 26, 2016 | 09:47 AM
  #39
Forcefed86's Avatar
The OP isn’t running a bone stock LS1. You were, end of story. Your “fuel is fuel” comment and cam babble isn’t relevant. The argument is that a bone stock LS1 isn’t putting 890 (or 870hp uncorrected) to the tires on 21psi.
Tell yourself whatever you need to, I’m done explaining it to you and won’t crap up this guy’s thread anymore.
Old Feb 26, 2016 | 10:39 AM
  #40
Thanks for the responses guys. I'll take the car out this weekend for some 3rd gear pulls and see how the boost response is and report back. My 2 mile, city street, commute to work each day isn't very conducive to testing, lol. Is there anything in the combo that stands out as a potential cause of the "slow" boost build, other than possibly the turbos are just too big?
On a positive note, I've been playing with the trans brake, and can very easily and quickly build a full 20psi at only 4k rpm. So that gives me hope that at the track I will have full boost for a much greater portion of the run. I don't plan on launching at that level, but at least it will be much closer to peak boost when I first start moving, vs having to build up.
