Turbo drain lines
Old Feb 21, 2016 | 06:52 PM
gearhead89's Avatar
Default Turbo drain lines
Have a question about my twin turbo drain line setup. My turbos are mounted where the battery and fuse block were and I want to run the lines to the front cover. The lines would be wrapped just under the factory alternator and have a slight incline. Will it work or is it going to back the oil up too much?
Old Feb 21, 2016 | 09:43 PM
lmt0705's Avatar
Lines have to pitch down. Why don't you want to run them to the pan?
Old Feb 22, 2016 | 04:36 AM
stevieturbo's Avatar
As long as they flow well under gravity with no restrictions they should be fine.
If they dont, it wont.
Old Feb 22, 2016 | 01:17 PM
Ping King's Avatar
If there is a slight incline for a bit, they will work like a trap in a toilet. They'll still flow, but may not be the best.
As said above, you could try and go right into the pan.
