turbo for low rpm boost
Old Mar 1, 2016 | 07:53 PM
vipergtrdj's Avatar
Default turbo for low rpm boost
I am interested in putting together a turbo kit for my LQ4 in my truck (2000 Silverado). I would like something that spools quick, around 2000rpms, since I never rev it up very high. Looking for something for lower rpms, quick spool, and to give it more torque.
Belows are a couple turbos I have lying around - not sure what would work best for it. What should I be looking at in terms of turbo specs ?
1st turbo
Compressor Trim: 59 A/R:0.70 Inducer:56.20 Exducer:72.9
Turbine Trim:62 A/R:.84 Inducer:73.90 Exducer:58.3
2nd turbo
Compress Trim 69;A/R 0.66; IND 68.7MM; EXD 97.8MM
Turbine Trim 92; 1.05 A/R; IND 87.4MM; EXD 77MM
Old Mar 1, 2016 | 08:23 PM
JoeNova's Avatar
Restricted User
Laying around? Looks like you copy/pasted the specs from an ebay ad lol.
The 2nd one is an ebay GT45. I would probably run that one. The first one is way too small for a 6.0. It would probably make boost in a hurry, but you'd have the rev range of a diesel.
Old Mar 1, 2016 | 08:38 PM
vipergtrdj's Avatar
Lol. Got them from a buddy, they probably are off ebay. The gt45 one any good ?
Old Mar 2, 2016 | 01:55 AM
gtfoxy's Avatar
Go with #2.
It won't respond quite the way you want but #1 will choke it. I ran a 68 on my blazer & it was all in by 3k RPM.
Old Mar 2, 2016 | 07:04 AM
JoeNova's Avatar
Restricted User
GT45 is a very common turbo around here. All around solid budget performer.
