when should i expect to run out of fuel??
Old Mar 15, 2016 | 12:02 PM
SLOW SEDAN's Avatar
Originally Posted by lmt0705
What pump/pumps are you running
I'm using an Aeromotive Eliminator at 43PSI base and holds steady 67-68PSI under boost. Only thing changing is my IDC as I make changes. Seems to go up 8-10% for every 3-4MPH. I was at 90-91% before the last round of mods that added 25-50lb of fuel flow and now Holley says I'm exceeding my capacity in the base fuel chart via red cells in the chart.
Old Mar 15, 2016 | 11:31 PM
RonSSNova's Avatar
I have ID 1000's at 60 base.
E85
Holley 12-1800
FP in the log follows along nicely until half way through high gear where at 18 psi boost FP drops to to 75 psi.
AFR rock solid and duty cycle is right at 100%.
Just an example.
