Procharged LS1 breater tank setups
Old Mar 12, 2016 | 11:22 PM
stanggreg90's Avatar
Default Procharged LS1 breater tank setups
Have a forged ls1 procharged on 14lbs what are you guys using, pcv or catch cans with breathers? Was going to use breather cans with -10 hose. Have been blowing out my rear main seal and other gaskets from to much crank pressure.
Old Mar 13, 2016 | 08:07 AM
NitrOmm's Avatar
Go take a look at Mighty Mouse catch cans.
PVC can set up. ( it has a one way breather on it as well).
Great setup, you won't be disappointed.
Old Mar 13, 2016 | 01:42 PM
Toes's Avatar
How do you have your pvc routed now? I don't have a catch can on yet but have only saw oil in my intake pulling from the valve cover? I hope with a catch can on it will take care of that. I run mine right now per the instructions in the kit manual.
Old Mar 19, 2016 | 06:49 AM
forcd ind's Avatar
Last year I ran the LS-6 valley cover and a hose to a fitting behind the throttle body-during the winter build I noticed oil in the TB and vacuum lines
I looked at the MM setup, but couldn't swing it right now, so I used a cheap oil sep in the line-after a short drive, I had oil in the sep., so I switched from the valley cover to the truck PCV valve in the pass side, no more oil
I use a breather in the oil filler, so hopefully that allows some crankcase pressure to get out, since the PCV doesn't work with a loss of vac.
I also use a check valve in the PCV line so I don't blow boost into the engine
Old Mar 20, 2016 | 08:42 PM
King23's Avatar
Wouldn't you Benefit from running the ls6 valley with catch can together? Or would the pcv with catch can be just as effective?
Old Mar 21, 2016 | 02:48 PM
customblackbird's Avatar
torque storm super charger +10-12psi
Stock Valve covers, driver valve cover PCV valve into moroso oil/air seperator (3/8" ID hose), into a McMaster Carr one way check valve into 3/8" hose into the intake. Pass side valve cover with 3/8" hose into a vented filtered catch can.
The check valve opens (only in engine vacuum going toward intake manifold at .3psi) and is completely closed in the other direction (boost) so I can't pressurize the crank case when in boost. All air/pressre will be forced out the pass side valve cover into the catchcan. When out of boost and in vacuum the setup switches so the check valve opens and sucks crank case pressure out while fresh filtered air comes in through the oil catch can on pass side.
I haven't run it yet but close to starting it up. I figured the 3/8" hose should flow enough since stock was 3/8".
