Valve spring choices, PAC1218, or GM Performance?
Old Mar 15, 2016 | 06:56 PM
b4ctrooper's Avatar
Default Valve spring choices, PAC1218, or GM Performance?
Starting to dump money into my build. 6.0L, stock cam, and a home turbo system. Turbo choice not made yet, but shooting for 650-700 at the tire. My price fifference between the GM Perf springs is about half of the PAC springs. I'm trying to save in some areas to have more money for the turbo install. Anyone happy with the GM Perf springs in similar builds?
Old Mar 16, 2016 | 08:19 AM
hellbents10's Avatar
LS1Tech Sponsor
The GM springs will be great with the stock cam. I have made over 800rwhp with the LS6 springs in turbo LS engines with stock cams.
Old Mar 16, 2016 | 09:08 AM
69-chvl's Avatar
Lotta discussions out there regarding adequate spring pressure with turbo motors. I ran the LS6's as did Hellbent and then went to the 1218's and now dual BTR's. Never really noticed a difference other than what I think is increased lifter noise with more and more pressure.
Old Mar 17, 2016 | 07:52 PM
b4ctrooper's Avatar
Ok, thanks for the responses
Old Mar 18, 2016 | 08:37 AM
a4ls2goat's Avatar
wow. and people swear of valve float with the ls6 springs on 15psi. good to know
Old Mar 18, 2016 | 08:56 AM
69-chvl's Avatar
It would be nice to find a shim that would allow the use of the factory seal/seat so we could increase the pressure a bit
Old Mar 18, 2016 | 11:58 PM
Turbo D's Avatar
We went 9.25@148 with the $60 blue ls3 springs with a 216/220 trick flow cam on 18lbs with stock pushrods in a L33. It wouldn't go any faster with more boost so we figured we were maxed out spring/pushrod wise.
