bmr k member help please!!!!
Old Mar 19, 2016 | 03:28 PM
dracula4999's Avatar
Default bmr k member help please!!!!
I posted this in the suspension area but got no response. I have a bmr turbo k member. I installed it without the engine and it has always looked crooked. I noticed that the driver side engine mount stand looked like it was further back than the passenger side. After holding a straight edge on it I confirmed it was exactly 1" further back. Is this normal? First ls build so I don't know...if anybody has their engine out could you check for me. Any help would be greatly appreciated. For some reason I can't upload pics.
Car is a 97 z28 with an ls1 turbo k member.
Old Mar 19, 2016 | 05:03 PM
boostedxs's Avatar
I actually jus installed a turbo k member for my 01 ss last week. I can say that the fitment was poor but it did fit. first thing I would do if I were you is call bmr and ask them. I had to call them over a couple things and they actually have great customer service and helped me very quickly. I mounted my motor onto the k member then dropped the body down onto it and it bolted right up. so my motor is already in but if I can measure anything with the motor in just let me know..
Old Mar 19, 2016 | 05:04 PM
boostedxs's Avatar
I just realized your a 97 lt1 car. not sure if these will be different?
Old Mar 19, 2016 | 08:51 PM
It's a 97, but has the 98-02 k member. Tried calling bmr but they are out til monday. I still need to order motor mounts since the parts stores don't have any, if it wasn't for that I would have just tried it out. It would probably be hard to mea sure what I'm needing to know with your engine in, but thanks anyway.
Old Mar 20, 2016 | 12:40 PM
Boo"SS"t's Avatar
That's really the only way to find out, test fit the block with the tranny to see if all your mounting holes line-up. When I installed mine years ago, I noticed that the transmission tail was a bit closer towards the passenger side, the bolt holes on the trans cross member were just a tad off, but nothing a little tweaking could not fix to get them all lined-up. I guess having solid engine mounts didn't help either, if it was off to begin with.
