4.8 crank in a 6.2 block
Old Mar 23, 2016 | 01:13 PM
ls1_chevelle's Avatar
Originally Posted by Busa_rob
Does comp know they hired a ********? I mean, **** me for asking a question about a part that I have never seen talked about on here. And double **** me for trying to learn something new from someone who appearently works in that industry.
There are SEVERAL threads on short travel lifters. Seems like you have zero interest in doing any leg work yourself.
Destroked LS1 also pulls up a ton of responses on the ol google thing as an FYI.
as a double FYI, I dont work for Comp cams, I dont run their short travel lifters... I simply used the search function.
Old Mar 23, 2016 | 04:19 PM
DavidBoren's Avatar
Play nice gentlemen.
Old Mar 23, 2016 | 07:55 PM
panic's Avatar
Quoting Larry Widmer: "RPM means ruins people's motors".
BTW: you don't get the difference in stroke lengths as an RPM increase: 3.622 / 3.268 = +10.8%.
At the same tensile load on the rod (what determines breakage, assuming the valve train is stable and reciprocating mass is constant), the RPM increase varies as the dividend of the square roots: 3.622^.5 / 3.268^.5 = +5.3%.
7,000 RPM becomes 7,369, not 7,758.
Old Mar 23, 2016 | 08:59 PM
chevydarrell's Avatar
Sorry Guys,
I was away a couple days. I read the article from HotRod Mag.
It sounded very interesting. I have a 78 Chevy Monza that weighs in
at barely 2800. I can agree that it seems crazy to throw away all those
cubes, But I have also always been a sucker for the exotic. I am interested
to build the motor with a twin turbo setup. I most wanted everyone's opinions
so I could weigh the goods and bads and hopefully make an informed decision.
The porpose of the motor would be street and an occasional blast down the strip.
Thanks Everyone
Old Mar 24, 2016 | 12:24 AM
DavidBoren's Avatar
In a really lightweight vehicle, the shorter stroke can almost act as traction control by delaying the torque delivery a little bit. The smaller displacement will also be beneficial in this regard.
Using rectangle port heads instead of cathedral ports should also help move the majority of your available torque higher into the powerband.
Old Mar 24, 2016 | 01:14 AM
Blown06's Avatar
8 Second Truck Club
Some of you guys are acting like a drag car operates over the entire rpm range. Put the right converter in it and who gives a **** how much torque it makes. Just stirring the pot a bit lol.
Old Mar 24, 2016 | 09:50 AM
93camaro_zzz's Avatar
Exactly. That is why I have always thought the famous quote by Carroll Shelby, "Horsepower sells cars, torque wins races." Is a complete load of crap.
Old Mar 24, 2016 | 12:29 PM
IronBlocked's Avatar
They should sell those springs + that cam as a package, the 9k rpm LS package lol, like the supertech kits for hondas
Old Mar 24, 2016 | 04:18 PM
1CAMWNDR's Avatar
If you size the twin turbos, cam, and converter correctly that will take care of the torque for daily driving and launch at the strip. And at "barely 2800lbs" I think a twin turbo short stroke 330 would be excellent.
Old Mar 27, 2016 | 04:52 PM
Thanks Everyone for your input!! There are many things to consider!
Would be far cheaper to just put the turbo on a 5.3L and call it good.
thanks so much,
Darrell
